1968 cutlass vent window crank spring
Old Aug 24, 2019 | 06:22 PM
72cutlass408's Avatar
I am looking for the spring behind the door panel for the vent window crank. It’s just under 3” tall.
Old Aug 25, 2019 | 06:25 AM
jollyolds's Avatar
pm sent
Old Aug 25, 2019 | 10:30 AM
vistacruiser1971's Avatar
Olds Collector
1968 Cutlass Vent window crank spring
Hello Jolly: How much money is fair to charge for a window crank spring? It is the same for the body series 68-72? Regards, Trent in Los Angeles
Old Aug 25, 2019 | 10:50 AM
Not too sure if they are all the same. Was offered $5-15 plus shipping
Old Aug 25, 2019 | 10:51 AM
I am missing one
Old Aug 26, 2019 | 06:39 AM
442crzy's Avatar
PM replied back with details.
Old Aug 26, 2019 | 08:17 AM
Jollyolds sent me one thanks.
Old Aug 26, 2019 | 09:27 AM
allyolds68's Avatar
I've never seen a spring used on a 68 vent window crank
Old Aug 26, 2019 | 10:44 AM
Goes behind the door panel, on vent window crank shaft.
Old Aug 26, 2019 | 06:38 PM
Yellowstatue's Avatar
That spring is for the window crank, not the vent window crank... The vent window spring is shorter and has a small end and a big end. The big end goes against the door panel and the small end fits over the shaft and against the door inner panel.
Old Aug 26, 2019 | 07:20 PM
442crzy's Avatar
You are actually incorrect, that 3” spring pictured in the 1st post is correct for the vent window crank, it does in fact sit behind the door panel over the vent window crank shaft, the correct spring for the window crank is shorter and one end is larger than the other.
Old Aug 27, 2019 | 05:16 PM
So in other words I have it backwards. Sorry.
first442
May 25, 2019 08:22 PM
tcarroll
Dec 4, 2015 12:42 PM
tcarroll
Nov 19, 2015 02:19 PM
dnmfranco
Apr 8, 2014 06:29 PM
393tony
Apr 16, 2013 06:04 PM
