1973 Heater Control Valve
Old Sep 12, 2023 | 10:44 AM
72skytop's Avatar
I am restoring a 1973 Hurst/Olds. I am having trouble finding this control valve with the two spade electrical connection on it. I have tried my Napa parts guy and searched around on Rock Auto and FeeBay.
Does anyone here have one or know where I can find one?
Old Sep 12, 2023 | 12:37 PM
I worked at auto parts stores in the 80s and 90s (NAPA and CarQuest) and never saw one like that. Is there a number anywhere on the valve?
Old Sep 12, 2023 | 01:06 PM
I can see a number located on the switch but can't read it. I'm not familiar with a switch on the heater control valve for an Oldsmobile A-Body; but, I did find a bunch of switches which may or may not be applicable. My tiny bit of research indicates some vehicles used a heater control valve switch (i.e. Chrysler & Corvette). Some type of low pressure or high pressure cut-off switch. That switch (possibly the heater control valve) may not be the correct heater control valve for your vehicle?
Old Sep 12, 2023 | 01:10 PM
Here's a bunch of these kinda/sorta looking type switches...
https://www.google.com/search?client...57-oT3na2M3v5M
Old Sep 12, 2023 | 07:27 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Auto temp sensing/climate control? Sure looks like a temp sensor.
Old Sep 12, 2023 | 07:32 PM
aretubj's Avatar
I might have one
Old Sep 12, 2023 | 08:25 PM
Sugar Bear's Avatar
The valve and the switch are two different pieces. The switch threads in. Which piece do you need or both? Some replacement valves were made to work with or without the switch, a threaded hole was provided in the new valve in case it was needed.
Old Sep 12, 2023 | 08:36 PM
Sugar Bear's Avatar
The valve is on eBay and OldsObsolete shows one. There are two types, one allows coolant to flow with vacuum one doesn't. Try to determine which type you need before buying one.
Old Sep 12, 2023 | 08:51 PM
Due to part number consolidation, most valves have a threaded hole for a temp sensor. However, on the ones I have seen the hole is very small and is for a mechanical temp sensor (Bourdon tube style) and not that electric switch or sender.
This is a Four Seasons version.
Old Sep 13, 2023 | 05:09 AM
ROCKETMAN269V's Avatar
I was a line mechanic at an Olds dealership when these cars were new. Yeah, I'm old. Back then, IIRC, the idea was to have the blower motor run all the time to create a "positive pressure" in the cabin, to keep out exhaust fumes, etc. The only issue was, when it was cold out, you had cold air blowing on you. This temp sensor kept the blower from operating until the engine warmed up to a pre-set temperature.
Old Sep 13, 2023 | 05:18 AM
The valve on the 455 in my 71 98 looks exactly like the one the OP posted only it has 1 connector instead of 2. I'd have to check my receipts for a part number. I know there are other threads on our site about this part. FWIW, Oldsguy replaced this valve with a 5/8" heater hose barb on the 455 in his 69 Delta 88.
Old Sep 13, 2023 | 05:40 AM
deaddds's Avatar
Aha! So is this why I always hear the blower very slightly in my daughters 77 Cutlass? I was wondering if a sensor was out or something.
Old Sep 13, 2023 | 06:18 AM
Originally Posted by deaddds
aha! So is this why i always hear the blower very slightly in my daughters 77 cutlass? I was wondering if a sensor was out or something.
bingo!
Old Sep 19, 2023 | 12:01 PM
72skytop's Avatar
Thank you EVERYONE! I figured it out
Thanks to all your great replies, I have figured out what I need to do. I had a new heater control valve, but I did not realize that that sensor just screwed onto it. So I remove the sensor from my old valve and put on my new one. If I wouldn’t have posted this, I would’ve never known that could be done. Thanks to everyone who replied. You made a big difference. I now have what I need.
Old Sep 19, 2023 | 01:06 PM
Thanks for posting those pics, it really helped me with realizing what I had been looking at all through the years.
So apparently this is the threaded sensor hole on the Four Seasons 74602 heater valve. Too bad the threads aren't easily visible in their image.
https://www.rockauto.com/en/catalog/...ter+valve,6860
Old Sep 20, 2023 | 04:48 AM
On some models, probably without a/c, there is a single spade ground terminal that screws into the rear of the passenger side cylinder head to perform the same function.
ej69
Jan 6, 2022 05:18 AM
1973OldsDelta88Royale
Apr 21, 2019 08:07 PM
1973oldsmobile
Nov 8, 2015 06:49 PM
doc93
Jan 26, 2011 08:10 PM
toms66rgtop
Aug 31, 2008 09:58 AM
