1969 Cutlass 2 Dr vacuum door lock actuators Nos preferred
Old Jul 10, 2023 | 06:43 PM
69442murph's Avatar
Looking for vacuum door lock actuators for 2 door Cutlass /442. See photo.
GM part # 8730955 and 8730956 for nos
Not sure if 68 is the same but I assume it is.
4 door front doors carry a different part number, I assume the rod is different.
Mine do not seem to hold vac for much more than a couple of minutes.
Im building the doors and it would be great to find these before I put the glass in.
I would consider good used if proven they hold vac.
Thank you
Old Nov 20, 2023 | 02:36 PM
alsalp's Avatar
i have four door parts
Old Nov 20, 2023 | 03:17 PM
Loaded68W34's Avatar
Tim,
Heve you tried to use those in your car? They do not need to "hold" vacuum. They only recieve vacuum when you press the switch. So, as long as they have enough "strength" to move the lock mechanism, you should be fine.
Jake707
Jun 6, 2023 02:49 PM
69442murph
Feb 16, 2022 01:48 PM
BeenThere
Nov 19, 2018 10:47 AM
Niko
Sep 3, 2014 07:59 PM
blowitup
Sep 8, 2009 12:24 AM
