PCV Filter Valve
Old Jun 21, 2021 | 12:17 PM
OldsTechGuy's Avatar
PCV Filter Valve
Looking for PCV Filter Valve for my 1965 Olds 442, the part can also be found on a 1964-67 Olds 330 rocket Jetfire engine. these Valves plug into the Valve cover to enable PCV system to connect to snorkel. not easy to find, i am flexible on price if in decent condition. please text me at 310 617 3070.
im based on Cali. thank you guys, much appreciated. David
Old Jun 21, 2021 | 03:40 PM
Is this the setup you're looking for?
Old Jun 22, 2021 | 09:57 AM
hello joe -
yes the picture you attached on left looks like correct setup if you have that one... i see the air cleaner is large 442 style like mine. not sure middle pic. rigtht pic is driver side i have a breather where the grommet is.
david
310 617 3070
Old Jun 22, 2021 | 10:06 AM
I do not. That is P/N 387189 and is called a filter, not a PCV valve.
Old Jun 22, 2021 | 10:21 AM
right. the pcv sits inside i understand. thank you
david
Old Jun 22, 2021 | 10:40 AM
david
The PCV is in the other valve cover with a hose to the carb. Look at the diagram from the part book that I posted.
Old Jun 22, 2021 | 01:53 PM
VC455's Avatar
Barely Registered
In the diagram, the PCV is labeled "Valve Assy."
Old Jun 22, 2021 | 02:09 PM
RAG's Avatar
RAG
Text sent, assuming you want the one on the left which is a Lansing built car.
Old Jun 29, 2021 | 05:25 AM
thank you roger. david
Old Jun 29, 2021 | 05:36 AM
PCV has small hose that connects to carb. for 1965 442, anyone have opinion on whether hose connects to timed or untimed vacuum port on Carb (edelbrock 1406 ) ? thank you david
Old Jun 29, 2021 | 05:57 AM
The only thing that ever connects to ported vacuum is the distributor vacuum advance, and on newer cars, the EGR valve control and the evap cannister purge control. Everything else goes to straight manifold vacuum.
Old Jun 29, 2021 | 09:31 AM
ok so in back of actual manifold. the edelbrock however has a manifod vacuum nub on it... (1604). thank you Joe
Old Jun 29, 2021 | 09:50 AM
Actually any place on the manifold or carb that provides full time manifold vacuum is fine.
Old Jun 29, 2021 | 10:37 AM
Ok. Thank you Joe P. Very helpful. David
Old Jul 2, 2021 | 02:52 PM
Gerald Nickels's Avatar
I have a complete set up but not sure if it goes to side of air cleaner or snorkel. I do want $100 shipped.
Old Jul 2, 2021 | 04:50 PM
thank you gerald, found the parts. do appreciate your note.
ilanzo
Tech Editor's Desk
15
Sep 14, 2016 05:49 AM
boese1978
Jan 29, 2013 12:31 PM
RetroRanger
Aug 26, 2011 06:55 AM
apachemobile
Feb 5, 2010 04:59 PM
The_Jeremiah
Jan 24, 2008 12:11 PM
