3.42 gears
Old Sep 25, 2012 | 05:27 PM
Olds1971's Avatar
3.42 gears
Looking for good condition 3.42 gears. Replacing my stock gears in a 83 cutlass with them. Pm me if have any avalible sorry for spelling been a long day
Old Sep 26, 2012 | 06:27 AM
ROCKETMAN269V's Avatar
Question 3.42 gears
7.5" or 8.5"?
Old Sep 26, 2012 | 08:11 PM
Olds1971's Avatar
That part I dont know but someone told me those gears in my car would be bad... He said Id run like 2800 rpm down the highway which i heard there good gears so i dont know
Old Sep 26, 2012 | 08:25 PM
If you have an 83, chances are good you have the 7.5 rear end.
I'm just having 3:42's dropped into my 72 - that's a 10 bolt corporate rear with 8.5 ring.
Also note, the 7.5 pinion shaft is shorter, thinner than an 8.5, obviously smaller ring, and has a completely different yoke collar.
I have a set of 3:23's that may work, but I have to check the ring size and pinion. Are you interested?
Old Sep 27, 2012 | 11:41 PM
Olds1971's Avatar
Well one guy said for a daily driver not to use the 3.42 because I would run high rpm on the highway?? Whats the 3.23s like?
Old Sep 28, 2012 | 09:41 AM
Ok, first things first. You should have a 200R4 trans in the car. The 1,2,3 and OD ratios on it will compensate quite a bit for the taller gears. You will have higher rpms no matter what speed you're cruising, and at highway you're prolly going to see a significant change. I'm guessing right now you probably are around 2200 - 2300 at around 60 mph? With 3:23's you'll prolly be around 3000 rpms. That's not going to hurt the motor, it's just going to use a lot more gas.
I have to verify the 3:23's will fit a G body before I sell them in good conscience. If you want me to post some photos, I can do that. The ring and pinion gears are in very good condition, but do not come with the pinion bearing or shims. Just the gear and pinion.
Old Oct 1, 2012 | 05:41 AM
MXman112's Avatar
Complete G body rearend
I have a complete 8.5 Gbody rearend with 3.42 posi if your interested.
With the 200r4 and 235 60 14 in OD it cruises down the highway @ 70 just over 2k rpm. Depending on the cam you are using it may surge a bit when the converter locks up.
If you have 15s, go with 3.73 still runs about 2200-2400 rpm @ 70 and a blast to drive around town with any torque.
Old Oct 1, 2012 | 08:10 AM
MXman112 - I believe G body has a 7.5 rear end. Double check your measurements on the pinion shaft length and and diameter at the spline.
Old Oct 1, 2012 | 08:15 AM
Talking 8.5" G-body rear
[QUOTE=Allan R;460360]MXman112 - I believe G body has a 7.5 rear end.
Buick GNs, '84 H/Os and '86? 442s had 8.5"
Old Oct 1, 2012 | 08:56 AM
cutlassjoe's Avatar
Instead of creating a new thread...I have a 72' Cutlass / 442. 8.5 10 bolt. Looking for 3.42 gears please.
Old Oct 1, 2012 | 04:08 PM
MXman112's Avatar
I know it is an 8.5 without going through your suggestions. Some of us actually know what we are talking about when replying to others. Not a poke at you but sometimes you have to give other people credit for being somewhat informed or experienced.
Old Oct 1, 2012 | 05:10 PM
Point taken. I learned something new. Always thought G bodies were 7.5 from discussion with others. Now I know better.
I never intended my comment as a slam. I got burned on the web by a guy who sold me 3:23's that were guaranteed 8.5 and they turned out to be 7.5 . The shop doing the work said they were from a G body. So, my intent was solely to help. Should have spelled that out better I guess. I am just in the process of having 3:42's installed in my 72 because the 3:23's it was originally going to get weren't even close on the pinion.
Anyway, Good luck with the sale of your ring/pinion! I'll know better in the future
Old Oct 1, 2012 | 07:01 PM
MXman112's Avatar
Had a similiar situation with a series 2 vice a series 3 carrier, which by the way may help Olds1971.
Depending on the original gears in the stock rearend and or the series a special ring and pinoin set is needed. The ring gear is thicker in some cases when going from higher to lower gearing.
Old Oct 1, 2012 | 09:12 PM
I was just talking with some about that recently. The info they had said that a ring gear spacer would be needed if the series 3 ring gear was used with a series 2 carrier. Also there was a warning that it was not advised for an MT car, or if higher HP or or if there's a lot of traction, HP and/or weight involved
I did check with JD Race before buying my carrier. I needed to be sure it would handle a set of 3:42s.
Old Oct 2, 2012 | 01:32 PM
Olds1971's Avatar
Didnt mean to be gone for so long.. My trans is a 350 turbo
Old Oct 3, 2012 | 06:30 AM
MXman112's Avatar
With 3.42 and 235 60 15s your rpm will be a tad over 3K with a 350 turbo @ 70mph. This is real close to what the 3.23s are going to give you with the 14s.
With 3.42 and 235 60 14s " " 3.2K @70mph
Hope the info helps.
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
magnusdog
Sep 14, 2006 01:03 PM
