455 a/c brackets
Old Apr 21, 2010 | 05:06 PM
olds455's Avatar
455 a/c brackets
Hello, Im looking for a set of a/c brackets for my 70 cutlass with 455. I have the sbo brackets#398682 and 391366. they were bolted to a 403. I think i need 398684 and 399802. Please let me know what you have, Thanks
Old Apr 21, 2010 | 05:27 PM
jensenracing77's Avatar
i thought they were the same between the small block and big block?
Old Apr 21, 2010 | 05:32 PM
olds455's Avatar
I thought so too but the rear wont bolt up to the intake. Its about 1/4in off. Ive read the 70 has a different on in the early or late year.
Old Apr 21, 2010 | 06:50 PM
2blu442's Avatar
I may be able to help you but it will be the weekend before I can dig around to see what I have. If you haven't found the correct one by then send me a message. John
Old Apr 21, 2010 | 06:56 PM
olds455's Avatar
Will do John, I hope these other brackets are what I need.
Old Apr 22, 2010 | 03:58 AM
filbily's Avatar
hi-if the other guys cant help u -call-540-323-1499-thanks
Old Apr 22, 2010 | 05:26 AM
507OLDS's Avatar
I have this stuff.I have pictures of one type I removed from a 455.They are the 398684 and the 399802.If they don't work,I have some others.The Deltas & Toros had slightly different brackets,but in the same general location on the engine.
Old Apr 22, 2010 | 07:21 AM
olds455's Avatar
Brian, I sent an email. For what its worth I found on 442.com that it may be an issue with the aftermarket intake and not the brackets. I may have to mod the new ones as well. Let me know
Old Apr 22, 2010 | 07:46 AM
dc2x4drvr's Avatar
Yah, I noticed you have an Edelbrock intake, so plan on modifying your bracket, this hole almost never lines up..
I had to section the mounting hole to gain about 3/8", tigged it back together..
Old Apr 22, 2010 | 07:08 PM
olds455's Avatar
Thanks 507olds!
Old Jul 20, 2010 | 09:13 PM
STR-8_CHARGIN's Avatar
From my understanding all of the brackets are alittle different for each motor, but are still interchangable as long as you use the complete set of brackets. For example if you have a 455 you can't use a 403 A/C bracket with all of the 455 brackets, you would basically have to swap out every bracket so that the pulleys will line up properly. Not 100% sure about that, but thats what a 70 yr old mechanic with a 68, 70, and 72 Cutlass told me a few years back. Normally knowledge comes with age, so I certainly believe him LOL
olddaz
Aug 27, 2014 06:39 PM
ERIC27
Mar 3, 2013 11:14 AM
Rusty Boltz
Jan 29, 2009 11:37 AM
smyrna ranch
Aug 3, 2008 12:13 PM
TOONLOVESCHERYL
Jul 4, 2006 08:07 AM
