Stall/Gears/Intake/Cam
Old Jul 15, 2013 | 04:03 PM
Olds1971's Avatar
I have a stock Olds 350 in a 83 four door cutlass. Im looking for a good stall converter around 2800, 3.23-3.73 gears an aftermarket intake and a small cam for stock. Im also looking for a cheep alimunim radiator and an electric fan 16 inch. Thanks Im hoping to finish a cheep sleeper
Old Jul 15, 2013 | 06:22 PM
ferndaleflyer's Avatar
I have some good used Mondello cams
Old Jul 16, 2013 | 04:08 AM
ROCKETMAN269V's Avatar
Question Stall/Gears/Intake/Cam
What year is the 350; depending on compression ratio, etc. you may not want a "big" cam. Same goes for the intake. A gear will definitely help no matter which engine you have. Maybe a set of headers, too. Just speaking from years of doing this.
Old Jul 16, 2013 | 10:02 AM
Olds1971's Avatar
Its from 1972 any suggestions would be great! and any small cams ferndal
Old Jul 16, 2013 | 10:24 AM
Also if its mostly stock you don't need a 2800 stall either. The cam requirements set the stall.
Old Jul 16, 2013 | 04:44 PM
507OLDS's Avatar
I wouldn't go any higher than a 1500 converter,for a stock 350,even a mild one with a cam.
Old Jul 17, 2013 | 07:08 AM
I have some small hydraulic cams----I had them advertised on here awhile back but I'll check them and let you know.
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
quentinnw2
Nov 23, 2013 11:32 AM
monzaz
May 29, 2010 08:46 PM
denis
Apr 24, 2007 09:14 AM
