Rear deck filler panel
Old Sep 29, 2020 | 09:49 PM
stevengerard's Avatar
I need either a reproduction part or the cutout form a donor body of the filler section between the decklid and the rear window for the 70 W30 hardtop. Body is a 34487. It seems like the Supreme body has a reproduction part made for that but I can't find it for sale anywhere now. I also found an old post somehwere that showed it for a Chevelle, maybe with a little work that could be used. Open to good used, reproduction or other ideas (balsa wood and a gallon of bondo? ). Let me know what you have.
Old Sep 29, 2020 | 11:06 PM
4Speedy's Avatar
Check here
https://www.rustreplace.com/home/196...972-cutlass442
Old Sep 30, 2020 | 05:57 AM
Originally Posted by 4Speedy
THanks, I'll call them, that's the Supreme section I saw. I'll give them a ring.
Old Sep 30, 2020 | 07:01 AM
scrappie's Avatar
Correct me if Im wrong but I think this is the pc in question? If so it recently came up in discussion for a 69 resto. The gentleman who posted was told 68-72 are all same? I can't verify that but I would say 70-72 are the same. The panel in question was also called a tulip panel?
Old Sep 30, 2020 | 02:53 PM
Yep sure looks like the correct panel. And yes I need that. The company suggested above got back to me instantly and said they do not produce this part and they know of nobody else that does either. So I will need to recreate it or get it off of a donor car. I would say that any 77 or 87 panel will work. Supreme body looks like it would be different
Old Sep 30, 2020 | 04:18 PM
scrappie's Avatar
Yes supreme is different.
How bad is yours?
I removed one from the car Im working on which was a little rusty but not beyond repair. Ive seen much worse lately. This one being off the car would be easier to repair Im thinking but would still need repair.
Old Sep 30, 2020 | 04:26 PM
So yes, that is the panel I need. This is what mine looks like. Some duct tape and POR15 may fix it!
Old Sep 30, 2020 | 04:30 PM
scrappie's Avatar
Thats pretty rough
Old Sep 30, 2020 | 07:22 PM
Wow, very odd that the part for a Supreme is available but not for a 442? I thought all the aftermarket parts were geared towards the 442.
And I really liked the video of the Banshee in that link.
Old Sep 30, 2020 | 08:48 PM
I don't get it either unless the convertibles are more prone to rust there or its a bigger market but I'm with you, i'd think the 34477 and 34487 would be the largest market
Old Sep 30, 2020 | 09:03 PM
I doubt convertibles rust more often than hardtops in that area - I had both and the vert doesn't have anything to trap water and cause rust compared to a hardtop with the rear window gutter and chrome trim to hold water. I do think vinyl top cars of any body style rust more than non-vinyl top cars. Seen that way too many times.
Old Oct 1, 2020 | 04:53 AM
scrappie's Avatar
Yeah supreme is totally different design with a channel around all sides of window but they still rust out also. Reproducing a channel pc seems a lot easier than reproducing the pc that so many of us are after due to multiple layers of metal along with compound curves and stamping.
Old Jun 3, 2026 | 10:08 PM
TTT, Looking for another one. Body shop lost the one I found them 4 years ago. Have no idea if 68-69 would fit '70 but if someone knows please confirm one way or the other for me. Thanks.
Tiberian Fiend
Mar 19, 2024 05:09 AM
armycav0
Body work
May 21, 2018 12:10 PM
Russell Winkle
Apr 16, 2017 06:49 PM
62radarlove
Mar 3, 2012 03:17 PM
Tucsonbob
Jul 12, 2011 08:28 AM
