Deck lid filler panel for 1970 442
There is no filler panel between the base of the backglass and the decklid on a hardtop '70-72 S or 442.
So if you're referring to a hardtop 442 then maybe you mean the "panel" that runs along the base of the rear glass INSIDE the car??
OPGI sent you the one for a Supreme Holiday Coupe (4257 body style), which is the only one being repro-ed to my knowledge. It appears that you are looking for the panel that forms the upper edge of the trunk gutter and bottom window channel? There is a repro panel that is the complete package shelf and rear seat divider that is listed for the 68-72 Chevelles. I can't tell from the photos if it will also fit the xx77 and xx87 Olds body styles for those years:
It's about $400 and obviously there's a lot of work if you choose to install the whole panel.
Thanks Joe. We may have to see if we can work with what we have. I ordered through Summit and they had the application catologed incorrectly. Should have waited to get the part before the body shop removed it.
Oldssupreme
Jan 14, 2013 06:22 PM
