1964 330 timing cover seal
Old Aug 16, 2020 | 10:35 AM
REO442's Avatar
Wanting new correct seal for 330 SBO timing cover.
Old Aug 16, 2020 | 10:50 AM
Have you evaluated the cover seal available from RA? Application demonstrates 330 cid for:
OLDSMOBILE F85 1964-1972
OLDSMOBILE JETSTAR I 1964-1965
https://www.rockauto.com/en/catalog/...over+seal,5612
Old Aug 16, 2020 | 12:35 PM
The front cover (and thus the seal) is the same on every 1964-1990 Olds V8. The GM part number is 382663. This crosses to Federal Mogul (also National and Timken) 472082. Fel Pro sells the seal, but apparently only as part of the complete timing cover gasket set. I haven't been able to find a Fel Pro number for just the seal. Note, you may want to get the speedy sleeve for the balancer if there is any groove or wear on it.
Old Aug 16, 2020 | 02:31 PM
ROCKETMAN269V's Avatar
I have a seal cabinet at my warehouse. Let me check tomorrow; I use to stock the 472082.
Old Aug 16, 2020 | 02:56 PM
REO442's Avatar
Joe, Thanks for the heads up on the wear factor of the crank end, I had not considered that aspect, nor the component, to assure problem-free replacement. I will search out the sleeve. Thanks to the other respondents who provided part numbers. Jimm
Old Aug 16, 2020 | 03:46 PM
rocketscientis's Avatar
While your at it ....
Spoiler
gtuturbo
Sep 28, 2018 05:17 PM
Guillaume
Aug 20, 2018 01:31 AM
Napoleon1991
May 7, 2014 08:38 AM
VinMichael
May 27, 2013 01:30 PM
SIPLOWGUY
Apr 16, 2010 06:24 PM
