gas pedal assemble
Old Aug 20, 2020 | 10:45 AM
oldsmobilejim's Avatar
gas pedal assemble
Needing a gas pedal assemble for a 1971 cutlass with a 400 turbo. Thanks
Old Aug 20, 2020 | 11:46 AM
cdrod's Avatar
Rodney
Jim:
I have gas pedal assembly in my parts car that I will not be using. The car is not at my house, but I can get some pics for you on Saturday and post them here for you to see.
Rodney
Old Aug 21, 2020 | 05:42 AM
sounds good it needs to support the turbo 400 switch you should see it. You will need a 3/8 or 7/16 socket with extension. Thanks
Old Aug 21, 2020 | 06:37 AM
ROCKETMAN269V's Avatar
gas pedal assemble
I have a couple of T-400 already removed. Email me for pics, etc.: drolds1@bellsouth.net. Thanks, Bob.
Old Aug 21, 2020 | 09:23 AM
Bob Jim again are the 350 and the 400 gas pedal the same or do I need that too?
Old Aug 21, 2020 | 11:26 AM
cdrod's Avatar
Rodney
gas pedal assembly for TH400 w/downshift bracket.
Jim:
I checked the '71 Cutlass assembly manual and the 455cid/TH400 cars require an extra mounting plate for the electrical downshift switch. My parts car is a 350cid/TH350 and doesn't have this extra mounting plate for the switch. Hopefully ROCKETMAN can help you with this part. See attached pdf drawing.
Rodney
Old Aug 21, 2020 | 11:39 AM
The "gas pedal" itself is the same; however, as shown in the above illustration, the "levers" are different. The T-350 has an additional eyelet that the downshift cable attaches to. I'm not sure if that will interfere with the operation of the downshift switch. I have the complete T-400 pedal assemblies. I will get one out and send you pics via email. Thanks, Bob.
Old Aug 31, 2020 | 06:38 AM
Any results on finding gas pedal? Thanks
Old Aug 31, 2020 | 06:41 AM
I have the switch and bracket for the 400 just need lever.
Old Aug 31, 2020 | 07:53 AM
The TH350 bellcrank arm can be converted to TH400 configuration by simply removing the tab for the kickdown cable. Cut or grind it off. The switch and mounting bracket are available from repro houses.
Old Aug 31, 2020 | 04:21 PM
jollyolds's Avatar
i have the T400 lever
Old Aug 31, 2020 | 07:44 PM
rocketscientis's Avatar
Visualization
Anyome have pix ?
R8der4life
Jun 4, 2013 06:51 PM
vista cruiser 1
Sep 2, 2012 04:50 PM
vista cruiser 1
Sep 2, 2012 03:39 PM
jag1886
Feb 18, 2011 03:47 PM
jag1886
Feb 17, 2011 06:49 AM
