Looking for a fan for my 1967 442 with air conditioning. Original fan was replaced in 1983 with a Flex Fan and I would like to take it back to as original as possible.
I have one that was removed from a 71-72 350cid motor, I'm not sure this works with the earlier motors - it measures 19-1/4" across the blades. Here's a pic:
I took this off my 67 442 when I upgraded to NOS UNIT found hanging on somebody's wall that came home in a lunch box
nice shape 19.37 actual dia
Clutch clutches & fan fans..
Less exspensive by th dozen..
Thanks for your intrest
Reason: To edit
also have similar fan w/different clutch for 68 W-30 OAI application
front & bac of very nice 68 W-30 fan & clutch from a car that became a drag car therefore had no use for such foolishness
so it is low miles as well
obviously value on this is well and above the previous one listed here
clutch bigger and and badder and if you look close you can see ink stampings on face of clutch I have never seen before as most fan clutches the high mileage and all that stuff is long gone
they could be twins except 30 unit has a larger fan clutch
thought I posted that 67 units yesterday sorry
