6 Blade/19" Diameter Clutch Fan Fan
Old Feb 9, 2020 | 11:31 AM
skekas33's Avatar
Looking for a fan for my 1967 442 with air conditioning. Original fan was replaced in 1983 with a Flex Fan and I would like to take it back to as original as possible.
Old Feb 9, 2020 | 01:24 PM
cdrod's Avatar
Rodney
6-blade fan
I have one that was removed from a 71-72 350cid motor, I'm not sure this works with the earlier motors - it measures 19-1/4" across the blades. Here's a pic:
Rodney
Old Feb 9, 2020 | 02:58 PM
lunaboy's Avatar
The Rocket Astronomer
you need a 19 inch to clear the 66 67 shroud
i have many 66 - 70 ac fans and non ac
Old Feb 14, 2020 | 09:21 PM
rocketscientis's Avatar
Ffound 67 442 fan . looking for shroud
I took this off my 67 442 when I upgraded to NOS UNIT found hanging on somebody's wall that came home in a lunch box
nice shape 19.37 actual dia
Clutch clutches & fan fans..
Less exspensive by th dozen..
Thanks for your intrest
Old Feb 14, 2020 | 09:23 PM
Found 67 442 fan . looking for shroud
Old Feb 15, 2020 | 11:44 AM
Super fantastic.
also have similar fan w/different clutch for 68 W-30 OAI application
front & bac of very nice 68 W-30 fan & clutch from a car that became a drag car therefore had no use for such foolishness
so it is low miles as well
obviously value on this is well and above the previous one listed here
clutch bigger and and badder and if you look close you can see ink stampings on face of clutch I have never seen before as most fan clutches the high mileage and all that stuff is long gone
they could be twins except 30 unit has a larger fan clutch
thought I posted that 67 units yesterday sorry
72GoldOlds350
Apr 25, 2020 12:59 AM
JJSCUTLASS
Jun 21, 2015 01:53 PM
goldie442
Aug 9, 2014 08:11 AM
76olds
Apr 25, 2014 04:13 PM
jdana24
Mar 22, 2012 09:26 PM
