68 442 tach
Old Jan 28, 2022 | 08:51 AM
KCastl03's Avatar
68 442 tach
Searching to see if they have a non Ralley pack tach for next to the speedo? I currently have an aftermarket unit that’s junk retrofitted in there so I was seein if there was a non tic tock option and if so did anyone have one available? Thanks
Old Jan 28, 2022 | 08:57 AM
ROCKETMAN269V's Avatar
68 442 tach
On my '68 Cutlass race car, with factory dash pad, I installed an AutoMeter Monster Tach. It literally just pushed into the opening and was held in place by the pressure of the dash pad.
Old Jan 28, 2022 | 09:08 AM
And, here's another thread you might find worth reading:
https://classicoldsmobile.com/forums...i-like-106203/
Old Jan 28, 2022 | 09:19 AM
Those are all '70-'72 dashes; completely different from a '68-'69. There is no removable front trim plate on the '68-'69s and the gauges are mounted in individual plastic shrouds, which are then attached to the dash pad.
Old Jan 28, 2022 | 09:22 AM
You are correct, I'm wrong. Thanks for pointing that out.
Old Jan 28, 2022 | 09:26 AM
Thumbs up
Old Jan 28, 2022 | 09:28 AM
Old Jan 28, 2022 | 09:30 AM
So on my 70 I used a Sun Super Tach. I cut out a factory blank where the clock would be to mount it. Can you not do the same in a 68-69? I am not familiar.
Old Jan 28, 2022 | 09:35 AM
KCastl03's Avatar
So something like this one?
https://www.ebay.com/itm/AUTOMETER-3...-127632-2357-0
Old Jan 28, 2022 | 10:04 AM
Originally Posted by KCastl03
Bingo! That's the "Monster" Tach as they call it. You need to remove the mounting clamp and just gently push it into the opening where the clock would go. Hopefully your dash is still supple.
Old Jan 28, 2022 | 10:05 AM
See #4 above.
Jon442
Nov 25, 2017 05:55 PM
69ishHoliday
Oct 29, 2013 07:39 PM
alexrains
May 6, 2010 12:06 PM
rocketrickshaw
Jul 20, 2009 05:46 AM
66cv442
May 26, 2009 05:47 PM
