Tach install, looks a little different but I like it
Old July 6th, 2016, 06:13 PM
Almond900's Avatar
Figured I should put a tach in, I don't really like them on the dash, and I don't have a clock, soooo, here's what I came up with
Almond900 is offline
Old July 6th, 2016, 06:44 PM
72 Olds CS
RetroRanger's Avatar
yeah me too
RetroRanger is offline
Old July 6th, 2016, 06:52 PM
I have a Sun Super Tach II in the same place (looks very similar to RetroRanger's).
Stuffed it in there back in the early 80s.
Fun71 is offline
Old July 6th, 2016, 08:37 PM
same but different
don71's Avatar
Its a good spot to put it, easy to read. Mine too, has been there a long time.
don71 is offline
Old July 7th, 2016, 04:08 AM
Almond900's Avatar
All of your tachs look great like that, here I thought I was doing something new lol
Old July 9th, 2016, 06:39 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
That Sunpro tach fits like it is nearly stock, I have it too.
olds 307 and 403 is offline
Old July 11th, 2016, 11:08 AM
DJS70cutlass's Avatar
Not to threadjack but to all the people who have mounted their tach this way......what actually holds it in the hole? Is any modification necessary? I hope to use a Autometer 3711 (recalling number from memory)
DJS70cutlass is offline
Old July 11th, 2016, 11:34 AM
Almond900's Avatar
I just used the rubber insulated clamp that goes around the tach that came with it, put the tach in the hole and placed the clamp on the back side and tightened it up, I did place a thin piece of rubber around the tach so it wouldn't wreck the gauge panel if the tach vibrated a bit going down the road
Old July 11th, 2016, 01:32 PM
The Sun Super Tach is just the right size to slip into the hole in the face plate. A couple wraps of electrical tape and it becomes a snug press fit into the hole (see Don71's picture above).
If you want an inset look like RetroRanger's, then you will need to come up with a method of mounting it behind the face plate, where the clock would mount. I'll let him describe that method as he has done it and so far I have only read about it.
Fun71 is offline
Old July 12th, 2016, 11:26 AM
johncj5's Avatar
johncj5 is offline
Old July 12th, 2016, 11:32 AM
J69shep's Avatar
Looks fantastic. Nice work!
J69shep is offline
GAOldsman
August 19th, 2011 02:06 PM
57 rocket
February 2nd, 2011 07:03 AM
Aceshigh
September 21st, 2010 08:15 AM
csouth
May 22nd, 2009 08:00 AM
68Tom
April 16th, 2009 07:28 AM
Quick Reply: Tach install, looks a little different but I like it
