Tach install, looks a little different but I like it
Old Jul 6, 2016 | 06:13 PM
Almond900's Avatar
Figured I should put a tach in, I don't really like them on the dash, and I don't have a clock, soooo, here's what I came up with
Old Jul 6, 2016 | 06:44 PM
RetroRanger's Avatar
72 Olds CS
yeah me too
Old Jul 6, 2016 | 06:52 PM
I have a Sun Super Tach II in the same place (looks very similar to RetroRanger's).
Stuffed it in there back in the early 80s.
Old Jul 6, 2016 | 08:37 PM
don71's Avatar
same but different
Its a good spot to put it, easy to read. Mine too, has been there a long time.
Old Jul 7, 2016 | 04:08 AM
Almond900's Avatar
All of your tachs look great like that, here I thought I was doing something new lol
Old Jul 9, 2016 | 06:39 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That Sunpro tach fits like it is nearly stock, I have it too.
Old Jul 11, 2016 | 11:08 AM
DJS70cutlass's Avatar
Not to threadjack but to all the people who have mounted their tach this way......what actually holds it in the hole? Is any modification necessary? I hope to use a Autometer 3711 (recalling number from memory)
Old Jul 11, 2016 | 11:34 AM
Almond900's Avatar
I just used the rubber insulated clamp that goes around the tach that came with it, put the tach in the hole and placed the clamp on the back side and tightened it up, I did place a thin piece of rubber around the tach so it wouldn't wreck the gauge panel if the tach vibrated a bit going down the road
Old Jul 11, 2016 | 01:32 PM
The Sun Super Tach is just the right size to slip into the hole in the face plate. A couple wraps of electrical tape and it becomes a snug press fit into the hole (see Don71's picture above).
If you want an inset look like RetroRanger's, then you will need to come up with a method of mounting it behind the face plate, where the clock would mount. I'll let him describe that method as he has done it and so far I have only read about it.
Old Jul 12, 2016 | 11:26 AM
johncj5's Avatar
Old Jul 12, 2016 | 11:32 AM
J69shep's Avatar
Looks fantastic. Nice work!
GAOldsman
Aug 19, 2011 02:06 PM
57 rocket
Feb 2, 2011 07:03 AM
Aceshigh
Sep 21, 2010 08:15 AM
csouth
May 22, 2009 08:00 AM
68Tom
Apr 16, 2009 07:28 AM
