Need Hood Hinge Springs...GM # 574802
Old Sep 13, 2013 | 11:32 PM
Oseeker13's Avatar
Application History:
59-64 Olds excluding F-85
67 Olds excl. F-85 or Toranado
68 Olds excl. Toranado
If anyone has any additional vehicle application information about this part OR, any other helpful info. I'd be most glad to hear about it !!!...
Many Thanks,
-Oseeker13
Old Sep 14, 2013 | 07:05 AM
ferndaleflyer's Avatar
I have a Hollanders interchange application book out in the garage. I think those fit a number of GM cars----I think I have some.
Old Sep 15, 2013 | 02:45 AM
Oseeker13's Avatar
If indeed there is a Hollanders part number which is a direct identical GM replacement for a GM part #574802 I would be most glad to have this info. so that can verify it...
And should you have the springs, I'd be glad to hear more about them...What I need are new or used GM replacement springs...Not some aftermarket reproductions which may not have the correct fit and/or quality...
In any case, please provide further details...Thanks !!!
-Oseeker13
Old Sep 15, 2013 | 06:35 AM
pretty busy and haven't even been in the garage this week but will check when I get out there-----seems to me if the hinges are the same the springs would also be the same even if not listed separately.
Old Sep 15, 2013 | 06:44 PM
dreamcar41's Avatar
I have a set of complete hood hinges with the springs. 68 cutlass
Old Sep 16, 2013 | 12:36 PM
Oseeker13's Avatar
Need Hood Hinge Springs...GM# 574802...
Just as soon as you can get the information I will be glad to have it...
-Oseeker 13
Old Sep 16, 2013 | 12:48 PM
Oseeker13's Avatar
I shall assume that you would desire to sell the complete hinges, not just only the springs...Right???...How Much???...
Let Me Know....Thanks,
-Oseeker13
Old Sep 16, 2013 | 04:08 PM
I checked the book today and it is a 68 only item and dosen't list the springs separate. Only fits Olds---all of them.
Old Sep 16, 2013 | 08:20 PM
Oseeker13's Avatar
It appears that this seems true for 1968 Olds Hood Hinges, except possibly
the '68 Olds Toranado...Have read the thread in the "General Discussion" forum > titled:"Do They Fit"...This thread seems to suggest that '68 CUtlass hood hinges could possibly be slightly modified to fit in to a '68 Toranado...Some of the thread comments say "Yes"...Some say "No"...
Would also appreciate knowing if there is in fact an actual physical difference in both the springs and/or the hood hinges for the '68 Cutlass and '68 Toranado...We all know that different part numbers do not necessarily mean that there is any actual difference...
I would appreciate a definitive answer on these issues from somebody with first-hand experience...This would be most helpful...
Many Thanks in Advance,
-Oseeker13
Old Sep 17, 2013 | 06:11 AM
Like I said the Hollander book says 68 hinges fit every model of Olds that year including the Toronado, Big Olds, F-85.......It list no interchange with any other car of any year. 68 only.
In those days they would also sometimes say that wrecking yards say another item from another car will work----like they didn't know. But in this case it says 68 Olds only period.
Old Sep 17, 2013 | 06:52 PM
dreamcar41's Avatar
hood springs
well i got an extra set of hinges with the springs when i got the car. i can see if there is a number on the hinge. I was told they were off a 68 vista cruiser. the guy was gonna change them because apparently they open higher than the cutlass hinges.
Old Sep 17, 2013 | 11:19 PM
Oseeker13's Avatar
This reply should address this post, and the previous post of Ferndaleflyer:
As a result of conversation I had today with a GM specialist at Hollander, it appears that all 1968 hood hinges can be used with any '68 Olds...But, do be advised that some modification to the hinge bolt holes will likely be necessary, depending on the model the hinges came from, and into which model vehicle they are going, especially those bolt holes which align with the hood...
And know also, that different springs were used depending on the weight of the hood for that particular Olds model...
Dreamcar41, as regards your hinges, I would appreciate a part # taken directly from your Vista Cruiser hinges and, some detailed photos would be very helpful to confirm this information...
Let Me Know...Oseeker13
Old Sep 18, 2013 | 06:28 PM
dreamcar41's Avatar
hinges
well i cant seem to find a number on them. I held them up to my 68 hinges and they are not even close. sorry man. Scrap!
Old Sep 18, 2013 | 06:40 PM
rocwal's Avatar
DO YOU NEED A SET OF HINGES FROM A 68 OLDS 98 - DELTA -DELMONT ? IF SO I'M PARTING A 68 DELTA OUT AND GOT NICE SET OF HINGES ON IT .
Dan B
Old Sep 18, 2013 | 11:49 PM
Oseeker13's Avatar
Dan B
Hello Dan,
Sounds Very Interesting To Me...Will assume that these Hinges and Springs are GM originals...Please do provide me with the parts #'s and photos so that I may confirm everything...And please tell me the best way to reach you so that we can discuss price...
Thanks and Best Regards,
-Oseeker13
PS: I believe the '68 Delmont - Delta is a variation of the Olds 88 ???...
Old Sep 19, 2013 | 10:23 AM
rocwal's Avatar
hood hinges
I LOOKED AND COULD NOT FIND ANY NUMBERS ON THE HINGES , THEY ARE ORIGINAL AND STILL ON THE 68 DELTA . ANY IDEA WHERE THE NUMBERS ARE LOCATED ?
Dan B
Old Sep 19, 2013 | 04:38 PM
Oseeker13's Avatar
Dan B
Not sure where they would be...Suppose its possible they were somehow rubbed off...Would appreciate some good detailed photos of both Hinges and Springs...
Thanks,
-Oseeker13
Old Sep 19, 2013 | 06:29 PM
rocwal's Avatar
hood hing's
send me your e-mail address to d.rocwal@hotmail.com subject car parts '
I will take some while on car nd mail to you .
Dan B
RetroRanger
Nov 11, 2024 09:45 AM
442craig
Apr 23, 2015 08:51 PM
70Post
Dec 28, 2014 02:24 PM
ostie13
May 29, 2014 10:31 AM
Doc350s
Jun 14, 2012 09:29 AM
