1964,394 fuel pump
Old Sep 9, 2013 | 08:08 PM
windycity's Avatar
1964,394 fuel pump
Hello members,
Im looking for the mechanical fuel pump for a 1964 Olds Dynamic 88 with the 394 cid engine. Thanks. Shipping to 60603.
Old Sep 10, 2013 | 12:13 AM
Have you checked Fusicks and Kanter?
Old Sep 10, 2013 | 06:21 AM
59-59-59's Avatar
If you need a pump because you do not have one, I would HIGHLY recommend you stay away from Kanter or Fusick. Kanter wants $142.81 plus a $64 core charge. Thats $206.81. Fusick wants $115 plus a core charge of $125. That could be the most expensive '64 pump on planet Earth. Your better off finding a crappy pump and buy a rebuild kit. That would be less than Fusicks core charge alone!
Old Sep 10, 2013 | 07:44 PM
windycity's Avatar
Thanks for replies. Since summer is just about over, Ill check the parts postings to see if one turns up over the winter. Thanks again.
Old Sep 10, 2013 | 10:00 PM
You could also replace the mechanical pump with an electric pump. That is what I did on my 64 98. The only problem is that it isn't OE.
Old Sep 10, 2013 | 10:16 PM
Charlie Jones's Avatar
Phantom Phixer
If your car was equipped with factory A/C make sure you get an A/C pump. It should have an extra return line fitting.
Old Sep 11, 2013 | 07:57 PM
deaddds's Avatar
Do you need a new one or a good core? AC? I have several pumps but not sure about any new in the box. Drop me a line at dead@mchsi.com if you still need one.
Old Sep 12, 2013 | 09:24 PM
windycity's Avatar
Thanks for all the feedback. As always, members prove to be an invaluable source of information.
I don't have the factory pump. I gave it to someone to examine it to see if it was faulty. When I looked at it, I couldn't determine if it was functioning properly. Well, now I cant get a straight answer from the mechanic. Its been months. I figured I look for another pump and save me the aggravation.
The car Im refering to is a 64 Dynamic 88 with no AC.
Deaddds, ill contact you to see if you can provide me with a pump.
Thanks all
Old Sep 13, 2013 | 09:35 AM
Don R.'s Avatar
If you can get the core back, send it to Then and Now Automotive for a rebuild. They do a great job for a reasonable price. Talk to Mike Casella. http://www.maritimedragracing.com/an...rts_cellar.htm
Old Sep 13, 2013 | 12:51 PM
Go to that mechanic and get your pump back ASAP!
Chekcing to make sure a mechanical fuel pump works is as easy as taking the fuel inlet hose off of the carburetor and cranking the engine over with the coil disconnected. It should take 10 minutes not months.
Old Dec 14, 2013 | 02:31 PM
Cman7713's Avatar
Hey windycity. I have a spare that was in the trunk from my 64 88. Its pretty caked with grease and debris and i havent checked it for functionality.
Its been a few months since the last post but figured id extend the offer since i didnt see a resolution. Im guessing youre in chicago from your user name?
Old Sep 22, 2016 | 12:30 PM
stickylifter's Avatar
Those of you that did the electric pump, what did you do about the return line?
Surner
Mar 12, 2013 08:09 AM
70worm
Nov 2, 2012 02:13 PM
1964starfire
Jan 3, 2011 04:05 PM
sshriber
Mar 22, 2010 06:16 PM
lowdynamo
Jan 10, 2009 03:36 AM
