Speed nuts for vinyl top trim
Old Apr 24, 2016 | 03:41 PM
rocketman77's Avatar
Does anyone know who sells the correct sized speed nuts/screws to secure the pot metal vinyl top trim pieces to my 1972 Cutlass S vinyl top?
I have the V shaped pieces that trim out the vinyl top to the body of the car, but these are pot metal items with the studs on the back that originally took a specific type fastener (speed nut) to secure to the car up in the quarter well.
where can i get these fasteners?
Old Apr 25, 2016 | 02:51 AM
Bump
Old Apr 25, 2016 | 05:27 AM
Rocketowner's Avatar
Smile
Do they resemble these below?Home Depot has the first one and also the "flat push clip style,but if they are like the other one,I know that Classic Industries show them in various sizes. You might also try Fastenal stores,or Autozone,or a local older Body shop.
You said Nashville area ,I am About 50 miles south of Nashville in Columbia.Good luck, Larry
File Type: jpeg
Old Apr 25, 2016 | 09:22 AM
It is the second picture type. I have looked at Ace Hardware and Home Depot. I will check Fastenal stores. Are there any around our local area here?
Old Apr 25, 2016 | 12:20 PM
70Post's Avatar
Try a NAPA Auto Parts or another auto parts store. The nut in his second pic is also called a "Stamped Nut"....it's stamped out of sheet metal.
Usually places like NAPA have hanging/carded fastener selections.
Lowe's Home Improvement likely has them as well in their Hillman brand line of fasteners. Here, they have them all laid out in a row of grey cabinets with pull out drawers in the bolt, fastener, etc section.
Old Apr 25, 2016 | 02:40 PM
scott_442's Avatar
Be sure to use the correct size which is probably 1/4". You could potentially snap off the studs trying to force on a smaller size which might initially appear to fit since the tip of the stud will start in the nut. Yes, this comes from first hand experience.....here's your sign!
Old Apr 25, 2016 | 05:54 PM
Fastenal shows locations @Elm Hill Pike,7004 Westbeelt Drive,and one in Franklin on Beasley Drive. They are also called Pal Nuts or Thread Cutting Nuts. Larry
Old Apr 26, 2016 | 01:33 PM
'70post is correct,Lowes has them in the specialty hardware
section in Automotive.A pack of 4 was .68c. Larry
Old Apr 26, 2016 | 04:52 PM
junior supercar's Avatar
depending on the size you need, I have a bunch of the second type. brand new. I need to check the box to be sure, but 3/8" sticks in my mind
Old Apr 26, 2016 | 05:07 PM
lemoldsnut's Avatar
Your local Lowes in the hardware department has a good selection of automotive fasteners in drawers. I have been there many times getting trim fasteners. I was surprised to find them there but happy as it is very close.
70Post
Mar 29, 2026 01:12 PM
Oldssupreme
May 28, 2013 05:35 PM
Tom442
Jul 25, 2011 02:46 PM
hinz57
Aug 10, 2010 08:16 PM
