wanted power steering pump pulley for 76 toro
Old Apr 18, 2016 | 03:47 PM
Bill D's Avatar
Hi does anyone have a pulley that will fit my 76 toro PS pump, I can't find one anywhere. It is a double belt type.
Bill
Old Apr 20, 2016 | 01:56 PM
jcdynamic88's Avatar
do you have a letter code for it? diameter? jc
Old Apr 20, 2016 | 03:26 PM
Octania's Avatar
perhaps the fairly common KH 399406
this unit has a KEY and is retained by a NUT so if you shaft has these features, that is what you need.
So sayeth the 1973-4 E-body listing in the 1975 PN manual on CD.
One assumes 76=75 but ck for the nut and keyway features to be certain.
OD ~6.6"
Prominent "KH" o the front typically
[EDIT]
Dang, not so.
Further down, 1975 E-body with AC says
PN 419713
2 groove, 6.48" dia.
Presumably the press-on type with no nut or keyway.
Bill D's Avatar
Hi
There is "KH" stamped on it and the diameter (overall) is 6.625" the bore is .740".
Bill
Old Apr 20, 2016 | 03:28 PM
Bill D's Avatar
The pulley is a press fit, no key or nut.
Thks
Bill
Old Apr 20, 2016 | 03:46 PM
Octania's Avatar
Database knows precious little of this item but does assert:
G-Body era engines; Lip only [for puller: no nut retention]
Groove to shaft seat dimension is identical to the nutted keyed KH so these should interchange if you swap pump/ pulley assembly so that the retention system remains a match.
Any G-body engine can probably donate.
More common than previously thought. Lucky you.
carl 87 cutlass
Nov 1, 2012 05:42 PM
1971viking
Feb 27, 2011 07:56 AM
1971viking
Feb 24, 2011 07:54 PM
MDchanic
Nov 19, 2010 02:54 AM
mcutlass1969
Mar 26, 2007 07:09 AM
