1970 Vista Cruiser Tank Sender Unit
Old Oct 3, 2021 | 09:12 AM
70vista's Avatar
Hi All, The fuel gage on my 70 Vista Cruiser went to full all of a sudden. Checked it out and the sender is open. I know this is a tough one to find but am in need of a working sending unit. It has 3 lines that go to it. 1/4",5/16" and 3/8". Thank You Steve
Old Oct 3, 2021 | 04:37 PM
Tri-Carb's Avatar
Send your unit to Tri-Starr Radiator for a rebuild.
https://tristarrradiator.com
Old Oct 3, 2021 | 05:27 PM
70vista's Avatar
Thanks for the information. I would like to find another unit so I don't have to have the tank out of the car a long time. Steve
Old Oct 4, 2021 | 02:19 AM
Tri-Carb's Avatar
I appreciate your position. I think Tri Starr can give you a quick turn around. If you picked a period of forecast bad weather to pull it, you would miss little. In any case if you find a used unit, you may want to have it rebuilt before installing it.
Just in case-- the symptom of "going to full all of a sudden" is so often associated with a bad ground connection for a wire leading back to the tank sending unit.
Old Oct 4, 2021 | 07:04 AM
70vista's Avatar
Thank You. If I do find one I will send it out to be rebuilt. I just don't want to tie up my lift for a extended period of time as I am always using it. Steve
Old Oct 4, 2021 | 10:16 AM
David Sloop's Avatar
There isn't really much to these.
I pulled mine and took it apart (A couple bent tabs) soaked it in white vinegar to eat away the rust.
Then sprayed the ends of the wires with electrical contact cleaner.
Wiggled the connections back and forth a bit repeatedly to clear the corrosion away between the parts.
Repeated the process until the unit moved the ohms meter up and down when moving the float up and down.
I'm far from an electrical guru, but this was something I'm pretty proud to have done myself.
BTW. The tank will come out with just a jack and removing the wheel. Might be easier on a lift, but doable on the ground.
Old Oct 4, 2021 | 01:09 PM
70vista's Avatar
Thanks for the information. The car season is almost done here so will do it in the spring but figured I would start looking. I put the tank in before installing the body on the frame but looks like it will slide out of there just have to tape everything up real good so I don't scratch anything.
Old Oct 4, 2021 | 01:33 PM
It's definitely tight. I had to pry the fender out slightly. The tank won't drop straight down. It comes out towards the wheel, and then down.
Fortunately, my Crusty is pretty flexible, but I did crack a little bit of his bondo... LOL
Old Jan 26, 2022 | 06:49 AM
70vista's Avatar
TTT...Still looking for a tank sending unit. I would like to find one to send and have rebuilt. Don't want the car on the lift for a extended period of time so want one ready to install. Thanks Steve
Old Jan 26, 2022 | 08:23 AM
Tri-Carb's Avatar
Did you send Tri Starr a picture of what you have left of your original? He may have enough parts to put one together for you.
Old Jan 26, 2022 | 04:30 PM
70vista's Avatar
I am hoping to find a good rebuildable one to send out for repair so I don't have the car apart on my lift for a extended period. Thank You Steve
Old Jan 26, 2022 | 05:04 PM
Tri-Carb's Avatar
Do you have the part number? If not, someone could post it. Once you have the number, search the internet for it and cross reference any interchange with Buicks and Pontiacs.
Old Jan 27, 2022 | 03:31 AM
Tri-Carb's Avatar
Check CT (CTC Auto Ranch) for the tank unit out of this Vista Cruiser:
http://www.ctcautoranch.com/Parts%20...rts%20Car.html
Old Jan 27, 2022 | 06:24 AM
70vista's Avatar
I don't know the part number. Will check my parts book to see if it is listed. I will email ctc but the tank is not there unless it is stored somewhere. Steve
Old Jan 27, 2022 | 06:33 AM
Tri-Carb's Avatar
Bone yards often remove, drain and store the tanks first thing.
Old Jan 28, 2022 | 06:32 AM
70vista's Avatar
I will contact them. Thanks Steve
Old Jan 28, 2022 | 10:24 AM
Tri-Carb's Avatar
Steve—if the Olds unit does not work out, ask them about a Buick Estate wagon tank unit.
Old Jan 28, 2022 | 02:25 PM
Tri-Carb's Avatar
I notice that CT Auto also has a 70 Safari wagon. I would investigate whether the Pontiac wagon's sending unit will interchange with your Olds.
Old Jan 29, 2022 | 06:27 AM
70vista's Avatar
They did not have the tank or sending unit for the vista. Still trying to figure out part number and interchange. Steve
Old Jan 29, 2022 | 07:38 AM
Tri-Carb's Avatar
Searching and placing a parts wanted ad on this station wagon forum is another option:
http://www.stationwagonforums.com/fo...4/?prefix_id=3
Old Jan 29, 2022 | 04:24 PM
70vista's Avatar
Thank You. Steve
Old Feb 2, 2022 | 05:58 AM
Tri-Carb's Avatar
Another lead:
1971 Oldsmobile Vista Cruiser (#71OL5482D) | Desert Valley Auto Parts (dvap.com)
Old Feb 2, 2022 | 07:02 AM
70vista's Avatar
Thank you. Steve
Old Feb 2, 2022 | 11:03 AM
Yellowstatue's Avatar
Grp. 3.107---6428036, 1968-70 exc A/C...6428004, 1968-70 W/AC wagons of course.
Old Feb 2, 2022 | 11:24 AM
Tri-Carb's Avatar
A Buick Sport Wagon without AC 68-70 is also 6428036. Nether a Buick Sport wagon with Ac or a 70 Buick Estate wagon are the same as the Olds numbers posted above.
GMPartsWiki - Parts Catalog 31 May 1980
Old Feb 3, 2022 | 06:02 AM
70vista's Avatar
Thank You for the information. Steve
Old Feb 3, 2022 | 06:03 AM
70vista's Avatar
Old Feb 3, 2022 | 07:37 AM
Tri-Carb's Avatar
!969-70 Pontiac Safari wagons match 6428004:
http://www.gmpartswiki.com/getpage?pageid=101092
Old Feb 4, 2022 | 06:37 AM
70vista's Avatar
Thank You that would widen the search parameters. Steve
Old Feb 4, 2022 | 07:23 AM
Tri-Carb's Avatar
Did the 70 Catalina wagon at DVAP not have this part?
Old Feb 4, 2022 | 04:35 PM
  #31
70vista's Avatar
Did not have that part, Steve
Old Oct 9, 2022 | 05:51 AM
  #32
70vista's Avatar
Still in need of this. I have contacted some yards without luck. If anyone has one working or not that would work. I can send it out for rebuild Thanks Steve
Old Oct 9, 2022 | 07:18 AM
  #33
Tri-Carb's Avatar
Did you check to see if this one has a donor?
https://www.dvap.com/salvage/1970-ol...on-70ol4222rb/
Old Oct 10, 2022 | 06:12 AM
  #34
70vista's Avatar
I may have called already but worth trying again. Thank You
Nov 1, 2019 07:44 PM
oldsbucket
Apr 10, 2013 10:36 AM
WoofWagon
Oct 18, 2011 09:39 AM
FloridaOldsGuy
Jul 21, 2006 07:18 PM
