Upper Steering column bowl
Old Nov 8, 2021 | 03:10 PM
JCMC64's Avatar
JC
Hello,
Need a cheap 70-72' Cutlass Upper steering column bowl in any shape...as long as it will bolt up. The part with ignition key barrel. Building a temp steering column for projects when needed. Upper bowl is all I need left. Not sure if 68-69' upper bowls would also work. Thx. JC
Old Nov 9, 2021 | 04:26 AM
ROCKETMAN269V's Avatar
Originally Posted by JCMC64
Hello,
............ Not sure if 68-69' upper bowls would also work....... JC
'68 and '69 are not the same. '69 was first year for key in the column.
Old Nov 9, 2021 | 10:07 AM
JCMC64's Avatar
JC
Thx. Didnt think so.👍🏻
Old Nov 10, 2021 | 10:23 AM
newmexguy's Avatar
Believe it might? be same through ‘76 in some instances. Pot metal construction. Have several loose, PM if interested. None of these are for TILT columns, to best of my knowledge.
Thats a whole different ballgame.
DaveS
W-27
May 15, 2015 08:08 PM
rodan
Aug 14, 2014 05:50 PM
Sampson
Sep 19, 2013 08:24 PM
webby
Suspension & Handling
38
Jan 5, 2013 02:49 PM
delta254
Mar 24, 2011 02:27 PM
