Upper Steering column bowl
Hello,
Need a cheap 70-72' Cutlass Upper steering column bowl in any shape...as long as it will bolt up. The part with ignition key barrel. Building a temp steering column for projects when needed. Upper bowl is all I need left. Not sure if 68-69' upper bowls would also work. Thx. JC
Believe it might? be same through ‘76 in some instances. Pot metal construction. Have several loose, PM if interested. None of these are for TILT columns, to best of my knowledge.
Thats a whole different ballgame.
DaveS
DaveS
