69 Delta 88 Intake Manifold
Old Jun 9, 2015 | 11:20 AM
Gaz Hog's Avatar
I have a 69 delta 88 with a 455 and looking for an intake manifold and air cleaner.
Old Jun 9, 2015 | 04:52 PM
tru-blue 442's Avatar
Old School Olds
I have a 70 455 2 bbl intake and breather if you can use them.
Old Jun 9, 2015 | 07:01 PM
I believe he's looking for a 4bbl manifold.
Old Jun 9, 2015 | 08:09 PM
Bernhard's Avatar
Do you have a picture of the air cleaner
Would a 70 455 delta be the same?
I will take a look what I have
Old Jun 12, 2015 | 01:09 PM
Gaz Hog's Avatar
Old Jun 12, 2015 | 01:54 PM
Stock or aftermarket? If you are looking for a correct, stock 4bbl intake for your car, that will be casting no. 398662, which is the same intake used on every 1968-69 BBO except Toros and the 69 H/O. This intake has a pocket for the divorced choke on the Qjet. It is not the same as 1970, which used an integral hot air choke on the carb.
Old Jun 13, 2015 | 04:31 PM
geardoc66's Avatar
I have a 4 barrel factory air cleaner assembly from a desert car. No rust, but will need the vacuum actuator replaced and it is missing the temp sensor. PM me if interested.
shamusj
Dec 18, 2014 09:28 AM
svnt442
Jul 17, 2011 04:43 PM
Gaz Hog
Mar 31, 2010 07:21 PM
jjatich
Jul 29, 2007 07:57 PM
SMOKEYMTNKUSTOMS
Oct 12, 2006 12:18 PM
