Need 455 HP Exhaust Manifolds & Frame Perches
Old Apr 13, 2009 | 07:25 PM
68/70 Cutlass's Avatar
Need 455 HP Exhaust Manifolds if not maybe a dual exhaust set with no crossovers. I have a 70 Cutlass and It has a 350 in it now. I need frame perches if mine wont work......or will they?? Thanks.
Old Apr 13, 2009 | 10:31 PM
2blu442's Avatar
Your frame perches will work IF you use the rubberized 350 motor mounts. You have to match the metal perches and rubber motor mounts, but either setup will work on a small or big block. John
Old Apr 14, 2009 | 03:37 AM
John- what do you mean match them? Thanks.
Dennis
Old Apr 14, 2009 | 04:08 AM
Bobsw32's Avatar
BobsW32
I have a set of used 455 exhaust manifolds... They are great for a driver. I welded a crack on one of the ears and then drilled out the studs and put new helicoils in them and serviced them and they are ready to bolt on....
$100.00 plus the freight to you
Old Apr 14, 2009 | 04:23 AM
That is a little steep for stock exhaust manifolds. You can buy a set of 455 headers from Summit for $180 + shipping.
Old Apr 14, 2009 | 05:18 AM
oldsconv's Avatar
Joe Padavano is the expert on engine mounts, but I have read his many posts. Basically (at least for 1970), if you are dropping in a 455, you can buy the 455 frame mounts (perches), but then need to buy the 455 rubber mounts that go with them (the rubber/metal mounts that attach to the engine). Or, you can just leave the 350 frame mounts (perches) on the frame and then use 350 rubber motor mounts to go with them on the 455 engine By matching, the previous poster means - use 350 frame mounts/perches with 350 rubber motor mounts, OR, use 455 frame mounts/perches with the 455 rubber motor mounts, but don't use 350 frame mounts with 455 rubber mounts, etc. In this way, the engine will sit at the right level.
Old Apr 14, 2009 | 05:47 AM
2blu442's Avatar
If those are W/Z manifolds that's not a bad price if they're in good shape other than the repairs.
Yes, Oldsconv explained what I was trying to say. Does that help you?
Old Apr 14, 2009 | 07:19 AM
Are they the W/Z ones?
Old Apr 14, 2009 | 07:20 AM
By george, I think he's got it...
Old Apr 14, 2009 | 07:22 AM
Thanks. I guess I can drill and run a bolt through the center since they are probably not as strong.
Old Apr 14, 2009 | 07:23 AM
Will my front springs be okay or should I get different ones?
Old Apr 14, 2009 | 08:45 AM
Bobsw32's Avatar
BobsW32
They are "W" and "Z"
Old Apr 14, 2009 | 09:04 AM
agtw31's Avatar
this is all you really need.
plenty of room,not a problem putting on.
Old Apr 14, 2009 | 10:38 AM
Cool. Email me at watnascar@yahoo.com
Old Apr 14, 2009 | 02:29 PM
No. All the SBO motor mounts currently on the market already have the interlocking feature built in. Adding a bolt is at best a waste of time and at worst may damage the interlocking feature. Just use 350 mounts in good condition. One P/N is Anchor #2328. These run about $3 apiece from RockAuto. It's not even worth messing with old ones.
Old Apr 14, 2009 | 05:25 PM
Thanks Joe.
fast67vellen2o
May 20, 2012 01:21 PM
WTony
Jan 10, 2012 07:18 AM
dlinderm
Jun 17, 2011 11:05 PM
80_cutlass
Jan 23, 2010 08:21 AM
cornwallis
Sep 21, 2009 08:44 AM
