Cruise carb linkage
Old Feb 7, 2009 | 02:28 AM
sworthy555's Avatar
Cruise carb linkage
I recently converted my 70 SX from a 2 barrel to a 4 barrel and the cruise carb linkage from the 2 barrel will not work with the 4 barrel. Does anyone have the cruise linkage that hooks to the carb for a 4 barrel?
Thanks and email sworthy555@aol.com
Old Feb 8, 2009 | 08:45 AM
Bluevista's Avatar
Registered
I don't have a linkage set-up but if you can figure out how to do it you may be able to modify yours or at least know if it's correct if you find one. I have a 2 barrel and cruise and may switch to a 4 barrel so I've been checking it out. If the '70 is the same as a '71 all the linkage is the same for a 4 barrel except for where the pivot for the bellcrank is located on the bracket, has two hole locations, same part as far as I can tell. The rod is also a different length but that's no big deal to lengthen or shorten.
mruders
Feb 4, 2014 08:15 AM
Oldskeeper
Feb 1, 2009 06:27 AM
sanemb
May 28, 2008 05:43 PM
granddaddy-O
May 23, 2008 08:27 AM
granddaddy-O
May 14, 2008 08:27 AM
