1971 4 Door 98
Old Feb 3, 2021 | 09:24 PM
Coach.34's Avatar
1971 4 Door 98
Anyone have any ideas of where to find replacement seats for these bad boys? Know of anyone parting a 4 door out?
Old Feb 4, 2021 | 04:27 AM
One of members; bigdooly, often parts 71-76 98s and Delta 88s. Send him a PM.
Old Feb 4, 2021 | 03:23 PM
Coach.34's Avatar
Thank you for the information. I will follow up.
Old Feb 4, 2021 | 05:23 PM
oldsmbl's Avatar
Ninety-eight
I have a 1972 Olds ninety-eight that I am parting out. 4 door hardtop. Would this help you?
Old Feb 4, 2021 | 06:45 PM
vintagepne's Avatar
You might try CTC Auto Ranch, www.ctcautoranch.com
Old Feb 4, 2021 | 07:01 PM
2blu442's Avatar
What color is your interior? I've got a green bench seat out of a 1970 Delta 88 4 door hardtop. I'm located down in Medford Oregon.
John
Old Feb 5, 2021 | 04:08 AM
60193W30's Avatar
Is the custom cruiser built on the same platform as the 88/98s...
If so I have a full interior out of a 71 CC...
Old Feb 5, 2021 | 11:35 AM
jaunty75's Avatar
The Custom Cruiser was built on the same frame (same wheelbase) as the 98, which is 3 inches longer than the 88 wheelbase. But, yes, I would think the seats out of a '71 Custom Cruiser should drop right in to a '71 98 and most likely a '71 88 as well.
Old Feb 9, 2021 | 08:39 AM
71MidwestDelta88's Avatar
im looking for a tilt steering column for my 71 delta, does your olds have one??
Old Feb 9, 2021 | 11:01 AM
60193W30's Avatar
Yes the Custom Cruiser has a tilt steering column...
Old Feb 9, 2021 | 12:38 PM
do you have a photo of yours, my interior is brown in my delta and reading the comments above about wheelbase suddenly im not sure if a CC colunm and a Delta column are the same length can you verify they are the same?
Old Feb 9, 2021 | 04:05 PM
ROCKETMAN269V's Avatar
Originally Posted by 71MidwestDelta88
............... and reading the comments above about wheelbase suddenly im not sure if a CC colunm and a Delta column are the same length can you verify they are the same?
According to my Mitchell Domestic Interchange manual, all '71-'76 Olds full size car's (88, 98, CC wagon) steering columns interchange, with the same options (fixed, tilt, travel, cornering lights and, yes, Air Bags).
Old Feb 9, 2021 | 04:50 PM
sounds good, im adding cornering lights to my 71 delta. is the column from a vehicle with cornering lights? If not i have to replace the turn signal switch too, what color is yours & how much do you want for it if its suitable for my vehicle?
Old Feb 9, 2021 | 08:01 PM
bigdooly's Avatar
88/ 98 / Custom. Cruiser same column
Old Feb 10, 2021 | 12:08 AM
thanks bigdooley, i think i'll get it if the price is right, all i need now to complete the task is a brown bottom section of the dash board, the section that has the glove box, mine has a crack & unfortunately the local vinyl repair man thats works mobile seems hesitant about my side of the villiage so i'll just find a used one
Old Feb 10, 2021 | 03:52 AM
bigdooly's Avatar
Unfortunately i have this section. Left side. But fear not, you said tan? I have a brown 72 lined up, with tan interior. It is in under over 2 feet of snow currently, and will take some work to get it from where it is, missing keys, flat tires, can't get my trailer past apron, (too narrow). I walked away from it, but due to people asking for parts from it, I'm gonna have to go get it, when conditions permit. Basically when the snow melts somewhat. The seats are shot & its a 2 door.
Old Feb 10, 2021 | 04:19 AM
60193W30's Avatar
Yes to the cornering lights on the CC
Old Feb 10, 2021 | 06:40 AM
now imma have to go look & see if my car has a single piece unit like that or if its the one split into 3 sections like another one i saw from a 72 delta i saw for sale, i'll look today & let you know & yes the tan one is what i need to match & if you run into a decent looking dash clock i'd take that too
Old Feb 10, 2021 | 06:42 AM
ok great thats the exact type of column i need, lets make that happen
Old Feb 10, 2021 | 06:54 AM
one last thing, i was told that the harness from the steering column that goes thru the firewall i may need to, in fact to make sure i have everything i can get the whole signal light wiring system from the bulbs to the steering column if you can get all of it
Old Feb 10, 2021 | 08:59 AM
i looked at my dash, its split into 3 sections at the bottom, here
you can see the crack right there in the middle at the bottom of the dash, also i could use two front ashtrays if they are from a non smoker vehicle
s a photo
Old Feb 10, 2021 | 09:14 AM
im adding these cornering lamps
And A tilt Wheel here
to make this a better car all imma want after that is bench seats from a regency 98 to complete the task b4 summer
Old Feb 10, 2021 | 11:23 AM
bigdooly, my dash looks like this disassembled
Old Feb 10, 2021 | 01:35 PM
bigdooly's Avatar
71-73 same dash. I will likely be dragging home a 71 98 when the snow melts some. I just can't get to it in this weather. There is a lot of snow on the ground and the car is in a yard I can't get my trailer in. It won't fit up the apron, or passed the gates. My tires where hitting the railroad tie retaining wall.
I need to dig it out, put air on the tires and hopefully find the keys they are supposed to be on the floor of the car. Then I can drag it out with the winch, & some chain or something. If I could have gotten my trailer in the yard I'd have had it here 3 weeks ago. Being a 98 its likely a tilt column, but the 71 98 I had had a standard column, so who knows I didn't look closely at the column.
Old Feb 10, 2021 | 02:20 PM
well user 60193W30 has a custom crusier with cornering lamps & tilt wheel, i waiting to hear back from him too, i'll let ya know what happens
Old Feb 10, 2021 | 04:23 PM
bigdooly's Avatar
Ok its gonna be a few wks I'm guessing before I get it. Weather permitting. Weather here not permitting much lately.
Old Feb 12, 2021 | 04:06 AM
oldschool85's Avatar
Any bumpers?
Old Feb 12, 2021 | 04:09 AM
60193W30's Avatar
Send me a PM w/ your # so I can text you pics. The car is in Wisconsin and I plan to get up there in mid March. The car is complete and the interior is all there... 455 TH400 Someone mentioned a clock... Its there too
60193W30's Avatar
Front and rear bumpers yes
Old Mar 4, 2021 | 05:46 PM
couldnt remember if i sent u my # so you could text me those pics, its 402 708 4869...i guess i didnt know if you already had pics or if you would take some when the weather got better & you made your trip to pick up the vehicle.
Old Mar 4, 2021 | 06:23 PM
  #31
bigdooly's Avatar
I didn't get the car yet, hopefully this weekend
Old Mar 5, 2021 | 07:25 PM
  #32
bigdooly's Avatar
Sunday I'm picking it up
Old Mar 7, 2021 | 10:03 AM
  #33
bigdooly's Avatar
There has been another delay in me picking this car up. I unfortunately was just notified of a positive test result for covid.
Old Mar 7, 2021 | 10:08 AM
  #34
jaunty75's Avatar
Are you symptomatic, or was the test done just as a precaution? In any event, I hope it's mild if you have it and that you're out and about quickly!
Old Mar 7, 2021 | 10:25 AM
  #35
2blu442's Avatar
Yes, take care of yourself and I too hope your symptoms will stay mild and it will pass quickly.
Old Mar 7, 2021 | 03:24 PM
  #36
bigdooly's Avatar
Thanks guys I appreciate the well wishes.
We have testing available on site at my job. I decided to get tested because it was convenient.
It has been several months since I've been tested last, that was due to someone else testing positive in my location.
I am prone to bronchitis. I thought I had a mild respiratory infection, which is something I deal with every year. At no time did I have a fever, or experience loss of taste, so I was surprised at the positive result. I was tested Thursday afternoon 3/4/21, notified earlier today of results. (Sunday 3/7/21) If I'm being 100% honest, have been feeling tired lately. The fact that I get my temperature taken every 5 minutes it seems, every where I go, kinda made me not even consider it could have been covid. We have our temperature taken before we are allowed to punch in at work.
So I never had a fever. I have been feeling a little lazy, and tired if lm being completely honest, but I wouldn't categorize myself as feeling "sick". I think putting to much faith in temperature checking is a mistake, as apparantly not everyone will have the fever. I guess i should consider myself lucky im not in a hospital on a ventilator. Especially considering I had a double bypass 11 months ago.
Thanks again guys, and stay safe.
Jim
Old Mar 8, 2021 | 09:48 AM
  #37
well i certainly hope & pray u just have a mild case & recover quickly
Old Mar 8, 2021 | 04:59 PM
  #38
bigdooly's Avatar
Thank you. It seems to be mild.
Old Jun 9, 2021 | 10:44 PM
  #39
dcmike783's Avatar
Seats for a 98
are these still available?
Old Jun 11, 2021 | 02:54 PM
  #40
bigdooly's Avatar
Parts?
Is what available?
what are you looking for.
