70-72 Console Harness
There was a post a week or so ago about this. Did you ask about it, I don't recall?
Anyways, there is no reason to buy a wiring harness from an old car or buy one that might be NOS. Either harness is going to be old and the wires will be worn and brittle. The best thing for you to do is to find a wiring diagram (they can be found in the FSM) and then wire a new harness yourself. If you want your car to be "original" then you can wire the harness in the factory colors and wire gauges.
Thanks for the response. have not thought about making one and I did not ask about it but I will look for the thread. But if you make one you have to get the correct ends for the bulbs and the harness connector correct?
electra483
Dec 28, 2010 02:36 PM
