Center console harness
Old Feb 1, 2012 | 04:26 AM
smietana's Avatar
Found one thanks, for all the response. Thanks to Eric (jensenracing77).
Old Feb 1, 2012 | 07:02 AM
507OLDS's Avatar
Tom,
The 71-72 console harnesses are the same.The 70 harness is different,all by itself.
The 70 console harness has plugs for the neutral safety switch that is located on the back of the automatic & dual-gate shifters.
Can you install a 71-72 harness in a 70? Yes.The 71-72 harness only has the 3 light sockets,for the shift indicator,rear light,and the storage compartment.If you do this,you will need the matching 71-72 console extension harness,that attaches the console harness to the main dash.
You would also need a 71-72 style column switch,for the bottom of the column,to operate your reverse lights,and to relocate the neutral safety function.it's been awhile since I did it,but I have done a few 70's like that in the past,when I converted them from bench to buckets/console,and the owners weren't concerned about originality.
Old Feb 1, 2012 | 08:29 AM
smietana's Avatar
Thanks Brian,
For the great info, so can I buy these new? Should I buy a 70 harness?
Old Feb 1, 2012 | 08:47 AM
jensenracing77's Avatar
it is a matter of what you have and what you are trying to do. does your shifter have the 70 neutral switch on it? are you converting from bench to buckets? do you already have a 71-72 harness? if you are converting from bench to buckets and don't have a switch on your shifter i would go with the 71-72 harness. the neutral switch would already be on the column. if you have a switch on the shifter and it is all good i would get the 70 harness. if you want it like original you will have to go with a 70 harness.
Old Feb 1, 2012 | 09:04 AM
smietana's Avatar
Yes I have the switch on the floor shifter, Yes I am going to buckets. Have no harness.
Old Feb 1, 2012 | 09:19 AM
with having the 70 switch on the shifter i would go with the 70 harness. i have a used one for 70 if you are interested. i will have to look at it but if i remember right it was a good one.
Old Feb 1, 2012 | 09:27 AM
smietana's Avatar
Yes, can you email me a few pics also? tom@spa-poolspecialist.com
jensenracing77
Aug 9, 2011 08:43 PM
electra483
Dec 28, 2010 02:36 PM
Olds luvr
Dec 23, 2009 09:54 PM
69442
Nov 29, 2009 08:50 PM
todd66442
Oct 26, 2009 01:13 PM
