71 olds rear axle needed
I have a line on an 8.5" 10-bolt out of a '71 Buick GS350. It has an open differential with 3.31 gears. It's pretty clean, since it's out of a Florida car. I won't have access to it until the holidays pass. Let me know if that's something you'd be interested in. Thank's.
I have a couple but shipping would be expensive. You might try looking through Craigslist to see if you can find something close enough to pick up. I believe the 1968-72 GM A-bodies would all bolt up although the length of the driveline may vary between them. The 1964-67 will also fit but the springs were bolted to the housings those years so that would need modified. Some thoughts to consider. John
I have an axle in my car that I want to get rid of so I can install the one that's sitting on the floor of my garage. I'm not all that far from you. Maybe we can work something out.
It's a 3.08 open, but you can get a power trax locker for it relativley cheap and convert it.
I have the 71-72 8.5" 10-bolt posi rears,all rebuilt & ready to run.Your choice of gear.
71-72 housing,hot-tanked,blasted,epoxy-primed,urethane coated satin black
GM clutch style posi unit,rebuilt with new GM clutches & 300lb S-spring
Motive gearset(any ratio)
Timken bearings/seals
Filled with fluid & posi additive and ready to run.Backing plates included,but no brake hardware. $950.00 plus the freight.
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
