need Rochester Quadrajet for 307 Delta 88 (1985)
Old Nov 18, 2010 | 05:57 PM
kandelino's Avatar
Hello!
I have some problems with my 1985 Delta 88 (307 Code Y) because my carb. has several faults and needs an overhaul.
The easiest way is to install another working carburetor. If somebody has a Rochester Quadrajet in good working condition, I will buy it.
Thank you!
Best regards, Andreas
Old Nov 19, 2010 | 06:00 PM
Olds24's Avatar
Carb
I have a few left. I will take 60 shipped. Let me know if interested.
Old Nov 19, 2010 | 08:47 PM
Rickman48's Avatar
I had a '86 Grand Prix 2+2 that I put 235k miles on the 305.
I put 3 carbs on it in that time, as the primary throttle shafts continued to wear out, causing a vacuum leak.
I think the 'computor carbs' have cheaper material baseplates!
If you find a rebuilt with bushings on the shaft, it'll probably last forever!
Old Nov 20, 2010 | 02:19 AM
kandelino's Avatar
@ Olds24:
got PM
Old Nov 20, 2010 | 10:53 AM
BILL DEMMER's Avatar
Just the facts...
rickman48,
the throttle body is made out of the exact same material-aluminum.
bill
Old Nov 20, 2010 | 03:55 PM
Rickman48's Avatar
Yeah, but I've never worn them out so easy - maybe there's something different with the alloy - and I'm not the only one, as I've seen many 'computer' carbs worn @ the shaft!!
Old Nov 24, 2010 | 02:40 AM
Just the facts...
one difference i've noticed is more load on the primary shaft due to more mechanical load being connected to it. once the teflon paint rochester used wears off, the steel shaft chews into the aluminum pretty quick. most units had double throttle return springs and a tv cable connected to the driver's side end of the throttle arm. i also believe rochester increased the clearance of the throttle shaft in it's bore by a couple thousandths due to the '80s engines running warmer than their predecessors.
bill
Old Nov 25, 2010 | 02:53 PM
kandelino's Avatar
Hello!
I still need a carb. Unfortunately Olds24 doesn't reply to my emails, so I have to find another offer.
Regards Andreas
Slabed831
Feb 29, 2012 06:18 PM
oldsman7
Jun 13, 2011 10:33 AM
mlouderback
Mar 23, 2011 05:42 PM
yeahbuddy
Sep 20, 2010 06:21 PM
sanemb
May 28, 2008 05:43 PM
