need Rochester Quadrajet for 307 Delta 88 (1985)
Hello!
I have some problems with my 1985 Delta 88 (307 Code Y) because my carb. has several faults and needs an overhaul.
The easiest way is to install another working carburetor. If somebody has a Rochester Quadrajet in good working condition, I will buy it.
Thank you!
Best regards, Andreas
Thank you!
I had a '86 Grand Prix 2+2 that I put 235k miles on the 305.
I put 3 carbs on it in that time, as the primary throttle shafts continued to wear out, causing a vacuum leak.
I think the 'computor carbs' have cheaper material baseplates!
If you find a rebuilt with bushings on the shaft, it'll probably last forever!
one difference i've noticed is more load on the primary shaft due to more mechanical load being connected to it. once the teflon paint rochester used wears off, the steel shaft chews into the aluminum pretty quick. most units had double throttle return springs and a tv cable connected to the driver's side end of the throttle arm. i also believe rochester increased the clearance of the throttle shaft in it's bore by a couple thousandths due to the '80s engines running warmer than their predecessors.
bill
bill
oldsman7
Jun 13, 2011 10:33 AM
sanemb
May 28, 2008 05:43 PM
