W-31 Heads
Old Feb 24, 2007 | 07:33 PM
z11375ss's Avatar
Senior Moment Member
W-31 Heads
Looking for a set of W-31 heads preferably from a 68. Good to perfect condition desired. Missed a set on e-bay last month by not acting fast enough. Jim
Old Feb 25, 2007 | 06:04 AM
2blu442's Avatar
Since the W-31 used the same casting number, arn't they the same heads as the common small valve ones? Can you take a set of regular heads and cut them out for larger valves? I know the small valve big block castings can be cut out for large valves. I had a set of small valve E heads cut out for 2.07 intake and I believe it was 1.72 exhaust. They also put in hardened seats at the same time. John
Old Feb 25, 2007 | 07:18 AM
z11375ss's Avatar
I'll have to check my machine shop. Much easier to do it that way anyhow. Thanks for the suggestion. Jim
64 CUTLASS KEN
Dec 7, 2020 06:43 AM
olds4life
Dec 25, 2012 12:56 AM
Oldsmaniac
Nov 1, 2010 06:37 PM
gearheads78
Nov 10, 2009 09:31 PM
DarkStar
Oct 21, 2009 07:35 AM
