WTB 68 2dr. Cutlass Transmission tunnel.
Guys I'm looking for a section of the tunnel marked out in the picture below. What I would like to find is the tunnel from an actual 68 model car that came with a column shift automatic. I understand that most people consider the 68-72 cars to be the same part, but I have another tunnel from a different year 2dr. cutlass and while it is very close it is not the same. I plan to fit the part and then butt weld the seam to try and hide my screw-up. LOL. I'm really only interested in a very nice piece with no rust or damage to the underside from a transmission banging around due to a bad transmission mount. If you have something that might work let me know. Thanks
Mike
mmaner@suddenlink.net
Mike
Mike
Mike
beyond the factory seam, you can attach the replacement at the factory seam.
Cut the factory spot welds with a spot weld cutter to remove the piece to be replaced.
The rest, of course, will need to done as you originally planned.
I usually try to break at the factory seams when I do this kind of resto
to make the repair as inconspicuous as possible..
This won't be perfect, but, it'll be a little neater installation.
Hi Mike
I have this one for your consideration
from a 68 or 9 I forgot what car I chopped it out of...
Scott
contact me directly if you would like
Scott68gto@comcast.net
Scott
Mike
trimmed it a couple inches towards the firewall
boxed it and
shipped it today at lunch break
tracking thru fedex being pmed to you........
also
Thankyou for the very smooth transaction !!
very nice Gent .....pleasure dealing with you
Scott T
boxed it and
also
Scott T
Wow! That was fast. I can't hardly get thru McDonald's that quick. LOL Thanks Scott, and I really do appreciate your help with this. Maybe I can get that old 442 on the road for New Years.
Mike
Mike
2blu442
Dec 16, 2013 07:14 AM
