Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
U joint hitting transmission tunnel
Old Jun 16, 2015 | 08:38 PM
patmills's Avatar
442forsure
I had a new Centreforce clutch installed and I used an Energy Suspension polyurethane transmission mount instead of the stock one. If I accelerate hard the Ujoint thumps on the tunnel. Also one of my shifter links rubs on the tunnel - in otherwords the transmission is higher than it was before I changed the clutch. If I compare the old trans mount to the new one, it is a little lower but not much and the same applies if I compare the old one to a new stock trans mount. Right now there is very little clearance between the tunnel and the Ujoint and shifter linkage.
Is is possible to get a lower transmission mount? The new stock transmission mount is 1 and 7/8 inches high and the Energy Suspension one is slightly higher.
Thanks for your help.
Pat Mills
Old Jun 17, 2015 | 06:25 AM
allyolds68's Avatar
Pat Mills
There was a steel plate that came in the package with my Energy Suspension tranny mount that was suppose to go underneath the mount. It was less than 1/8" thick but my u-joint was hitting as well so I removed it. It completely solved the problem and I haven't had any issues with the plate not being installed.
Old Jun 17, 2015 | 06:26 AM
Use the shorter trans mount.
Old Jun 17, 2015 | 08:59 AM
patmills's Avatar
442forsure
Thanks Mike. We wondered about that but because the instructions said to install that plate, we thought it might need it for stability.
How long have you been driving your car since you did that?
Pat
Old Jun 17, 2015 | 09:36 AM
allyolds68's Avatar
Pat
4 years
MikeManer
Apr 29, 2014 07:39 AM
Oldracerjones
Mar 30, 2014 04:27 PM
2blu442
Dec 16, 2013 07:14 AM
37OldsCoupe
Mar 2, 2013 12:23 PM
Tucsonbob
Jun 6, 2011 11:06 AM
