Th350 Intermediate and Direct Drum Cushion Plates
Old Jan 11, 2016 | 09:01 PM
VinMichael's Avatar
Tore down a th350 trans and it turns out I'm missing the cushion plates for the direct and forward clutch stacks. Would be glad to take em off your hands. Let me know if we can work something out. Thanks
Old Jan 12, 2016 | 05:00 AM
ROCKETMAN269V's Avatar
I have numerous T-350 & T-400 cores. I should have what you need already out. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jan 12, 2016 | 01:42 PM
toymobile's Avatar
Probably left it out to FIRM UP THE SHIFT,
Johnny
Old Jan 12, 2016 | 05:34 PM
VinMichael's Avatar
Johnny
Most likely. It didn't have any check ***** either. All but two of the forward clutches are completely SMOKED.
Old Jan 13, 2016 | 07:55 AM
Originally Posted by VinMichael
.....It didn't have any check ***** either.
Are you talking about the check ***** in the valve body or the ones in the drums/pistons?
Old Jan 13, 2016 | 04:00 PM
VinMichael's Avatar
Valve body. Come to think of it, I am missing 6 springs for the forward clutch piston as well. When I took it apart they weren't all there.
Old Jan 14, 2016 | 04:46 AM
Leaving out some of the springs is not unusual; that makes it shift a little firmer. Not having ANY check ***** in the valve body , not so good. Is it possible that you may have dropped 1 or 2 when you took it apart? Various "shift kits" instruct you to leave out certain check *****; but, I have never seen one that would have you remove all of them. What are your plans for this transmission?
Old Jan 14, 2016 | 05:14 AM
toymobile's Avatar
Need one check ball for reverse, other wise will burn a set of clutches??? May be the original problem??
Johnny
Old Jan 14, 2016 | 05:41 PM
VinMichael's Avatar
I could have dropped checkballs when I took the transmission apart. I even looked around on the ground when I noticed they were missing to verify.
My plans are to rebuild it to replace the Jetaway in my 64 Cutlass. It will go behind a 350 olds and possibly a 455 in the future. I might take it down the drag strip every once and awhile. I am following the instructions in Ron Session's TH350 book, as well as the mods in this link:
http://www.crankshaftcoalition.com/w...0_rebuild_tech
Johnny
All but two of the forward frictions are down to the metal. All other clutches looked decent. I'm not sure what the issue was exactly. The seals on the forward piston seemed pretty hard to me.
Old Jan 19, 2016 | 03:11 PM
VinMichael's Avatar
Found a forward wave plate. Anybody have a direct drum wave plate?
Local Hero
Sep 22, 2014 09:40 AM
RAMBOW
Apr 14, 2014 04:14 PM
seanm12
Aug 20, 2013 05:40 PM
Tedd Thompson
May 1, 2013 09:11 PM
oldsbucket
Vista Cruiser & Wagons
Mar 13, 2013 05:27 PM
