steering wheel insulator cushion
Old Jun 24, 2010 | 01:28 PM
Tedd Thompson's Avatar
Well I got problems right here in Forest Ranch. Horn will not shut off,seems the Insulator cushion has compressed under the horn ring and the weight of the ring will set it off. Any one know where I might find such a part? And ya this is for a 1955 olds convert.
I'm trying to bubble gum it to gether with shoe goop as I speek, but this is definley not a concourse fix, and doubtfull it will hold together for any length of time. Any help would be appreciated....Tedd
Old May 1, 2013 | 07:39 PM
idel0817's Avatar
Hi,
Check Fusick.com - sue they have one
Old May 1, 2013 | 07:55 PM
Not sure about the '50s Olds, but I foxed a '60s F_rd with a similar problem by cutting pieces out of a Bondo spreader and using them as insulators.
Old May 1, 2013 | 08:55 PM
I'm not sure why this post came up after two years but thanks for your interest.
The fix.
For those who may have the same problem a replacement part is available through Fusick part# 566369 but it is not as thick/ robust as the original and requires careful attention to the tightness of the steering wheel to get it also to not ground out when the wheel is pressed to the lock....Lost in the fifties ...Tedd
Old May 1, 2013 | 08:59 PM
Cause a newbie was lurking, but glad you got it fixed, it only took almost 3 years.
Old May 1, 2013 | 09:11 PM
D'oh.
Local Hero
Sep 22, 2014 09:40 AM
RAMBOW
Apr 14, 2014 04:14 PM
seanm12
Aug 20, 2013 05:40 PM
oldsbucket
Vista Cruiser & Wagons
Mar 13, 2013 05:27 PM
oldsca
Aug 16, 2010 04:50 PM
