3.23 Ring and Pinion
Old Jan 14, 2019 | 06:40 PM
Terry Wright's Avatar
Looking to get my 1970 442 back to original rear end ratio of 3.23. Anyone have a suggestion as to where to source this ratio ring and pinion? Thanks in advance for any assistance!
Old Jan 14, 2019 | 06:59 PM
scrappie's Avatar
Try Jim, he is very helpful.
http://jdrace.com
Old Jan 15, 2019 | 07:18 AM
oldsmobiledave's Avatar
Which diff and which parts now
Does your car still retain it's original Oldsmobile Type O differential and what is your current carrier and ring and pinion combination?
If you still have a Type O and want to go back to a 3.23 you may need more than just a gear swap depending on what you have now.
Old Jan 17, 2019 | 11:43 AM
Scrappie - thank you for the information.
Oldsmobile Dave - I am out of the country and can't remember for the life of me if it has the original style differential. I calculate it currently has 3.73 gears based on mph/rpm.
Old Jan 17, 2019 | 11:52 AM
3.73 is not a ratio available in the O-Type, so if your calculations are correct then you have a different rear, likely either an 8.5" 10 bolt or a Chevy 12 bolt.
The closest O-Type gears to what you calculate would be 3.42 or 3.91.
Old Jan 17, 2019 | 11:54 AM
Fun71 - thank you!
Old Jan 17, 2019 | 12:07 PM
11971four4two's Avatar
MOTORHEAD
3.23 in a 12 bolt cover type O factory gear is hard to find. Also the factory POSI carrier is only used on 3.08 and 3.23 ratios this is another part that is hard to find
If some one changed the complete axle out of your car , then you will have to figure out what is in there now.
I do have a complete 3.23 ratio rear axle removed from a 1971 442 and am located in maple grove Minn
As well as a 3.08 POSI ratio rear axle from a 1970 442 with 12bolt cover
Old Jan 17, 2019 | 12:47 PM
ROCKETMAN269V's Avatar
I have several complete oem type "O" rear ends. This would be correct for your '70. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Jan 19, 2019 | 09:54 AM
Thank you guys. I will be back in the country in a couple of weeks and will double check the rear-end and my calculations on ratio. I will be in contact once I have a better understanding of what I currently have in the car.
Old Feb 9, 2019 | 05:38 PM
SmirchIs#1's Avatar
If all you end up needing is a 3:23 ring & pinion for a 12 bolt "O" rear,I have a very nice used GM set for $100.Dennis in NY 518-234-2480 or 518-528-2646 cell
Old Oct 15, 2021 | 07:18 PM
oldsmobuser's Avatar
Hello SmirchIs31. I know this thread is a couple of years old but I was wondering if you still had your 3.23 Type "O" ring and pinion gears for sale? If you do or don't can you please send me an email at davec191145@gmail.com or text me at 757-235-1006? Thanks and take care.
67Rocket
Drivetrain/Differentials
18
Apr 25, 2016 10:28 PM
sbFALL63
Jan 10, 2016 01:04 PM
onetogofast
Jul 25, 2015 02:48 PM
Tim305
Feb 17, 2014 07:06 PM
