69 350 Exhaust manifold
Old Feb 11, 2012 | 06:52 PM
spate51's Avatar
Looking for a left hand (drivers side) exhaust manifold for a 1969 Cutlass w/ 350 ci. Standard manifold for dual exhaust
Steve
El Paso
Old Feb 11, 2012 | 07:02 PM
2blu442's Avatar
Hi Steve
I've got several of those, price would be $15 plus shipping. Which may be another $15! So lets see if someone closer has one to save you some shipping dollars and use me as a last resort if you don't find one at less that $30 total costs. John
Old Feb 11, 2012 | 08:18 PM
spate51's Avatar
I don't mind paying the $30. I am up to my neck in a 69 cutlass rebuild and as I am trying to bolt up the LH exhaust system (from InLine Tube), find that there is a big difference between the diameter of the exhaust pipe and the manifold outlet. If it is not a problem, if you could measure the diameter of the manifold outlet and it matches my exhaust, would like to make a deal.
Don't know why I am surprised though, there are many odd GM parts in this car already.
How's the weather in OR? We used to live up north in Olympia, WA for quite a while.
Regards
Steve
Old Feb 11, 2012 | 08:22 PM
2blu442's Avatar
Regards
Steve
I'll measure that for you tomorrow afternoon. The drivers side small block manifold was the same for many years and are very common. So you have one but its a different size than the pipe? John
P.S. we've had a very dry winter with much nicer weather than normal. I'm whispering that as I know some members here have been putting up with many feet of snow!
Old Feb 11, 2012 | 08:57 PM
spate51's Avatar
I'm going to take one more look in the morning an make sue I didn't screw it up. Already know the car has a 65 chevy application muncie M22 on it and a 84 chevy quadrajet.
Thanks for checking.
Old Feb 12, 2012 | 06:54 AM
Dave Siltman's Avatar
Make sure you do in fact have the correct exhaust manifold, and contrary to what you may have been told, the exhaust manifolds for ALL '69 350 engines were the same, regardless of single or dual exhaust. The dual exhaust had a "Block-off"----not saying this was the most efficient for the car, but probably was for Oldsmobile's bottom line!
Old Feb 12, 2012 | 10:16 AM
spate51's Avatar
After a new look in the morning, the problem is that the exhaust tube flange doesn't fit flat against the manifold exhaust flange. The ideal solution would be a small "donut adapter" (I do not know what the exhaust guys call it) that fits between the manifold and the tube or I will pull the forward tube and try to put about a 5 degree bend in the front before it turns up to the manifold.
I know about the standard exhaust manifolds. This engine had the crossover pipe cut off and was capped with a 5" stub tube in front of the oil filter rather than the blocking plate.
I had this same model of car new in high school (my first car)
Thanks for the replies
Steve
El Paso
atkinsom
May 29, 2013 06:39 PM
dallasite21
Feb 17, 2010 07:22 AM
terrysolds
Jan 6, 2010 06:23 AM
Southern_Hospitality
Mar 11, 2008 01:51 PM
