'69 350 exhaust manifold
Old Jan 1, 2010 | 11:54 AM
terrysolds's Avatar
I bought a '69 with headers and want to go back to stock exhaust manifolds since I plan long trips and don't care as much about performance. I'm concerned about heat damage to the starter. It has Code 5 heads. What exhaust manifolds will fit the 350? Anyone had experience with Thornton Reproductions replacements? Thanks Terry
Old Jan 1, 2010 | 12:38 PM
2blu442's Avatar
Welcome to the site Terry! I don't think you'll have problems with stock manifolds overheating the starter, they don't heat it up anything like the headers do. I don't have experience with the Thorton repops but hopefully someone here does. Factory manifolds are pretty common so if you decide to go back to them post a parts wanted ad with your city/state or the nearest large city. That way you may be able to find a set close by and save on shipping costs. What you can do for dual exhaust is block off the crossover pipe between the two manifolds and run two pipes toward the back. That's a pretty common mod and if you use the search option on this site I believe you'll find some threads discussing that. From what I've read there never was a factory dual exhaust for the small block engines. Just ones that had the crossover blocked. John
Old Jan 1, 2010 | 01:44 PM
Dave Siltman's Avatar
'69 exhaust manifolds
Hi Terry, I have the manifolds you are seeking. The heat problems you are asking about should not exist with the stock manifolds. if you choose to run dual exhaust, you will need the block-off. There was not a different manifold used for dual exhaust---just the block-off. I am in Maryland.
Old Jan 1, 2010 | 01:57 PM
calgarycutty's Avatar
hey terry where do u live i would be intrested in your pair of used headers if u live close !!!
Old Jan 1, 2010 | 01:58 PM
or even trade for my orig good shape exhaust manifolds
Old Jan 2, 2010 | 05:27 PM
Oldsguy's Avatar
Past Administrator
Glad to have you here with us Terry.
Old Jan 6, 2010 | 06:23 AM
terrysolds's Avatar
Thanks for the info. I'm posting a parts wanted add to try to find a source near Dallas.
atkinsom
May 29, 2013 06:39 PM
arodenhiser
Apr 23, 2010 06:41 PM
dallasite21
Feb 17, 2010 07:22 AM
Southern_Hospitality
Mar 11, 2008 01:51 PM
