Wanted: 1964-65 2" Fan Spacer w/bolts
Old Feb 8, 2012 | 09:46 AM
mrolds69's Avatar
Looking for an original 1964-65 2" fan spacer w/bolts + washers (hopefully!) part # 1361930. I think some or all of the numbers may be on the part. Used on ALL 6 cyl Olds models 64-65. Looks like the one in the pic attached. Let me know what you have. Thanks guys!
Old Feb 8, 2012 | 03:25 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have one of them here. I just mic'd it and it measured 2.099.
So, 2.1 not 2.0.
And the part number is 403635
Hope this helps, instead of creating more confusion for you.
Page 8 Here:
http://wildaboutcarsonline.com/membe...ooling-Oil.pdf
The one in your pic has a short nipple in the front. The short nipple spacers were on the pontiacs and buicks. Olds had a longer nipple.
About 1/2 " of protrusion.
I remember this because I've had to beat the living crap out of the olds ones to get them off since they sit in the bore so deep.
Old Feb 8, 2012 | 07:26 PM
mrolds69's Avatar
Re: Fan Spacer
Hi J-(Chicago), thanks for the response! Yeah...it's a little mystifying, but I think that's the part I need if it looks like the one in the pic I attached. The parts book I have says it's the # that I posted and says it's 2". But they may have changed that number later. 1/10" won't matter, it should work. Weirdly, in the parts book link you gave me, the same part is listed with different diameter sizes. If it looks like the one in the pic, with the larger round diameter on both ends I'll probably take it if it's available. You can PM me with cost and SH to 02771 MA. Nice if I could snag the bolts, too. I know there are some Chev 2" spacers, but they have only one big round end, the other end is like an X. That might work, too. I'm only going by the info I can find. Let me know if you can help, and thanks...I appreciate it!
Old Feb 9, 2012 | 05:41 AM
ROCKETMAN269V's Avatar
Post Fan Spacer
Just an FYI; the bolt pattern on the water pump differs amongst the different makes. Be sure that you get the correct one or the holes won't line up.
Old Feb 9, 2012 | 06:10 AM
mrolds69's Avatar
Thanks for the info Rocketman, Ididn't know that! I figured a Chevy would be the same pattern.
Old Feb 10, 2012 | 12:44 PM
mrolds69's Avatar
Got one coming from a member! Should be good at least for now......thanks for the responses.
toymobile
Dec 12, 2015 09:57 AM
nolabigdawg
Oct 25, 2014 11:50 AM
jdana24
May 14, 2014 12:37 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
