70-72 Vista Cruiser rear brake drums
I could use a few pairs of rear brake drums for the 70-72 Vista Cruisers.These are the wider 2.5" shoe,and are not the same as the regular Cutlass/442 or flat top wagon.As long as they have plenty of meat left to be turned,and are not all pitted & cratered,they should be fine.
Napa has the brake drums available from their warehouse, part number 440-1022. If you cannot get them there you could then cross their number at another parts supplier. They list for $86.10 each, wholesale, cheaper.
I have been able to get a lot of odd things from NAPA,but the drums were a no-go.It's been awhile,but I don't remember if they had them catagorized wrong or what.The wheel cylinders were a fiasco to get,but I was able to get them.I'll try that number,and see if it is what I already had before.
Brian, you can get new drums from Rock Auto...that's where I got mine. $44 each...$20 to ship...I offered my used set to you because I figured you wanted to save money...also, rear wheel cyls from Davesdiscountauto.com...#18E621 $70.12 for a pair...free shipping! By the way, the drums are a Centric part...I believe the # is 122.62005.
I would still be interested in your used drums.The purists like the originals.I have a few pairs of the Vista backing plates,but not enough drums.You can put these on regular Cutlass rears,and any other GM rear that has the same flange,and still keep a stock look.
Yes.I have done this for a few rears that I built.Another brake option,is the mid-70's A-body 11" rear drums.These have an 11"x2" shoe,so it's the same width as what you have now,but larger diamater.Same installation procedure.You need the backing plates,different wheel cylinders,and the drums.I am pretty sure the 11" drums will clear everything behind a stock 14" wheel,but not 100% sure.I only built the rear,so I did not install it,nor do I know what the person had for wheels.I don't have any other 11" backinmg plates,to try that again though.
All of these different brakes/backing plates,from the same era,have the same bolt pattern flange on the axle.The fullsize cars had something different.
Good to know.I think all of the 11" set-ups I found,were under mid-70's Gran Prix's,and I'm not sure what other cars could have come with them.They were an option,so not all of those cars had them.
brake drums
if i can help send a pm or call.
john @847-508-5090
drums
just a quick note of interest, so are the shoes, 2.5
John, I think you may be mistaken. Fronts are 2", as are rears....except the vista. Fronts are 2", rears are 2 1/2".....obviously I am talking A-Body cars...
Yes, just make sure you get vista wheel cyls...they have a larger bore(1"), I believe the fronts and rears on non-vistas are 7/8"....also, with the wider shoe, you need the longer pins.....
Olds S/W Rear BRAKE DRUMS & WHL CYLS
If you wnat NEW ---- CORRECT ----- Rear Brake Drums & Rear Wheel Cylinders -- give me a call -- I'm at the library to use computer -- and have to confess I don't know their part numbers off the top of my head.....
S/W Rear Drums were -- of course, as you know, wider.......
Best to call me -- Craig -- 516 - 485 - 1935... New York....
skaboy 40
Brakes/Hydraulic Systems
Apr 12, 2007 08:22 AM
