"KG" PS pulley
Old Feb 2, 2012 | 03:22 PM
Indy_68_S's Avatar
"KG" PS pulley
KG - 388403 needed...since I ran my original over with my lawnmower... d'oh.
Doesn't have to be perfect, just not bent/warped/beat/wallered/etc...
I have a bent/chewed up one for trade if necessary !
Thanks!
Old Apr 22, 2012 | 05:48 PM
Indy_68_S's Avatar
Bumpity...
Old Apr 22, 2012 | 06:53 PM
2blu442's Avatar
I'm digging for parts for several people right now. Would you tell me, does this pump have a single or double belt pully? Are there holes in the pully or is it solid? I know I've drug home several 1968 engines over the years, but locating the correct part is a little like a treasure hunt! I need a much larger garage with lots of shelf space to be organized John
Old Apr 23, 2012 | 06:12 AM
Indy_68_S's Avatar
Single pulley, no holes... Looks like this...
Thanks !
Old Apr 23, 2012 | 06:22 AM
2blu442's Avatar
Well, I snapped these pictures yesterday afternoon. It has the right letter code, but its on a 1971 engine and I don't see any numbers stamped into it. Does this look right? Do I need to measure the diameter to make sure its the same? John
Old Apr 23, 2012 | 06:33 AM
Indy_68_S's Avatar
Wow...That was fast!
Yep !
That's it !!!!
No numbers on mine...I x-ref'd them.
The only markings on mine are "KG" , "FRONT" & the letter "P" stamped on the front...
There's may be some other bits-n-pieces I could use, I'll pull up my list & PM you..
Thanks!
Old Apr 23, 2012 | 04:30 PM
Octania's Avatar
2blue watch for a pm on that parts engine
That is the correct pulley
Nut retained
keyway
no puller lip, so...
they are HARD to remove w/o damage
PLEASE inquire of me if you have not done this extraction before. I have a good method. It does require 2 workers. Possibly a torch.
Old Apr 23, 2012 | 08:56 PM
Indy_68_S's Avatar
Originally Posted by Octania
.....PLEASE inquire of me if you have not done this extraction before. I have a good method. It does require 2 workers. Possibly a torch.
I must've got lucky when I did mine. Zipped the nut off with an impact & with 1-2 taps with a rubber mallet it popped right off....
ROCKET VAPOR
Sep 19, 2012 08:08 AM
WTony
May 14, 2012 04:46 AM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
WTony
Jul 2, 2010 10:48 AM
