"KG" PS pulley
"KG" PS pulley
KG - 388403 needed...since I ran my original over with my lawnmower... d'oh.
Doesn't have to be perfect, just not bent/warped/beat/wallered/etc...
I have a bent/chewed up one for trade if necessary !
Thanks!
Thanks!
I'm digging for parts for several people right now. Would you tell me, does this pump have a single or double belt pully? Are there holes in the pully or is it solid? I know I've drug home several 1968 engines over the years, but locating the correct part is a little like a treasure hunt! I need a much larger garage with lots of shelf space to be organized
John
John
John
John
Thanks !
Well, I snapped these pictures yesterday afternoon. It has the right letter code, but its on a 1971 engine and I don't see any numbers stamped into it. Does this look right? Do I need to measure the diameter to make sure its the same? John
Wow...That was fast!
Yep !
That's it !!!!
No numbers on mine...I x-ref'd them.
The only markings on mine are "KG" , "FRONT" & the letter "P" stamped on the front...
There's may be some other bits-n-pieces I could use, I'll pull up my list & PM you..
Thanks!
Yep !
That's it !!!!
Thanks!
2blue watch for a pm on that parts engine
That is the correct pulley
Nut retained
keyway
no puller lip, so...
they are HARD to remove w/o damage
PLEASE inquire of me if you have not done this extraction before. I have a good method. It does require 2 workers. Possibly a torch.
Nut retained
keyway
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
81 regency
Apr 21, 2011 06:18 PM
