Looking for a POA valve for a 1973 98
Old Aug 22, 2022 | 07:47 AM
98 man's Avatar
Found my part no longer needed!!
Hi, As I stated I’m looking for a used POA valve and possibly a expansion valve for a 1973 Olds 98. The one on my car doesn’t work and it’s a aftermarket one so I’m looking to get a nice correct one and send it in to get rebuilt.
Let me know what you have with price and pics
Thanks as always
Greg
Old Aug 22, 2022 | 09:39 AM
rocketraider's Avatar
Oldsdruid
As you see both parts cover a lot of applications. Might make a search easier. Don't discount B-body Chevrolet, Pontiac and Buick for a source.
I do find it strange that the Cutlass and the cavernous big wagons share the part number.
Expansion valve:
POA:
Old Aug 22, 2022 | 10:06 AM
98 man's Avatar
[QUOTE=rocketraider;1448295]As you see both parts cover a lot of applications. Might make a search easier. Don't discount B-body Chevrolet, Pontiac and Buick for a source.
Expansion valve:
POA:
[/QUOTE
yes that is hard to believe that’s a lot more room to cool than a cutlass. I keep hearing there are 3 different styles not sure the differences between the 3
Greg]
Old Aug 22, 2022 | 12:24 PM
Greg, I hope you find one. Be aware that if you buy one and have it rebuilt you'll need to recharge the AC with R12 (unless you can have it calibrated for R134a).
Old Aug 22, 2022 | 01:38 PM
98 man's Avatar
Thanks for the heads up I wouldn’t use anything but R 12 works too dam good lol
Greg
Old Aug 23, 2022 | 07:48 AM
ROCKETMAN269V's Avatar
......I do find it strange that the Cutlass and the cavernous big wagons share the part number.
The difference in the size of the vehicles is made up in the evaporator. I got one out of big Buick and installed it in my C-20 Chevy 2-dr pick-up (Olds powered of course) and you could hang meat in that cab on a 90 degree day.
Old Aug 23, 2022 | 07:52 AM
[/QUOTE ....... I keep hearing there are 3 different styles not sure the differences between the 3.....][/QUOTE]
There were apparently two different "conventional" type POA valves and I believe that '73 is when they introduced the VIR (valves in receiver) system.
Old Aug 23, 2022 | 09:27 AM
98 man's Avatar
There were apparently two different "conventional" type POA valves and I believe that '73 is when they introduced the VIR (valves in receiver) system.[/QUOTE]
oh that is true they started that VIR later in 73 forgot that
Old Aug 23, 2022 | 10:47 AM
Oldsdruid
Also referred to as "2nd type". Only on A and E car and big wagons starting mid 73. Then they all got the accursed thing in 74.
The VIR could be rebuilt, but the system stayed open to atmosphere longer if you rebuilt the individual pieces of it. Most people just replaced the whole assembly with a rebuild which cut down vacuuming time considerably.
I've had both POA and VIR systems plus the orifice tube type. Orifice tube has always been the simplest to service to me, but that R4 compressor left something to be desired.
Old Aug 23, 2022 | 11:52 AM
AzChevs's Avatar
I have a 77 Cutlass, if that interchange works. It was on a low mileage car.
Old Aug 24, 2022 | 06:54 AM
442crzy's Avatar
PM sent
Old Aug 26, 2022 | 04:43 AM
Back to your original request. So, you're looking for the early type "external" POA and expansion valves? I have numerous used ones, as well as evaporators. Email me to discuss: drolds1@bellsouth.net. Thanks, Bob.
98olds73
Aug 29, 2021 05:09 PM
wal31
Nov 13, 2014 12:40 PM
Olds
Aug 18, 2011 07:30 PM
ambulanceguy73
Ninety-Eight
Jan 28, 2006 07:54 PM
<azlake@thedam.com>
Brakes/Hydraulic Systems
Jun 21, 2005 10:57 PM
