Wanted, a 1968 manual transmission 400 crankshaft.
Old Nov 15, 2022 | 12:29 PM
matt506's Avatar
Looking for a decent rebuildable 400 crank shaft that has is for a manual transmission, and or a #1 connecting rod. Prefer in the Milwaukee Wi area but willing to travel a little. Thanks matt
Old Nov 15, 2022 | 12:42 PM
Any 1968-76 BBO crank has the same stroke and can be machined for the pilot bearing.
Old Nov 15, 2022 | 12:52 PM
matt506's Avatar
Here it seems tough to find some one to drill it. I have a decent crank but it is a auto one and the rear seal area is pitted a bit.
Old Nov 15, 2022 | 01:11 PM
If your machine shop can't do that, I'd question their ability to do anything.
Old Nov 15, 2022 | 01:42 PM
1970greensupreme's Avatar
I have a crank that is .010 .010 that will likely have to go to .020 .020 that was drilled over 35 years ago but not sure it's not easier to find someone to drill it as opposed to traveling to CT or shipping it
Old Nov 15, 2022 | 02:03 PM
matt506's Avatar
I’ll keep it in mind. I wonder what shipping that would cost? Things must weigh 100lbs.
Old Nov 15, 2022 | 02:16 PM
OLDSter Ralph's Avatar
Rocket Racing and Performance Waterford, WI (262) 706-3277
Old Nov 15, 2022 | 03:33 PM
matt506's Avatar
What do you have?
Old Nov 16, 2022 | 08:12 AM
67OAI's Avatar
Old(s)GuysRule
Ralph is suggesting you talk with the folks at Rocket Racing about drilling your crankshaft for the pilot bearing. They would most assuredly have the expertise to do so and may be able to clean up that pitted area by the rear seal.
Old Nov 16, 2022 | 08:17 AM
matt506's Avatar
gotcha. At first the text didn’t come through or I missed it and only seen the map. I will contact them and see what we can do. Be a huge fix for sure. Thanks.
Old Nov 17, 2022 | 05:03 PM
DR_DAN's Avatar
Buy the automatic crank conversion bearing from Dick Miller.
Use a 5/8” drill bit and drill the end of the crank about 5/8” deep. Install bearing. I’ve done quite a few and works perfectly.
67red442discragtop
May 25, 2020 11:31 AM
88hurstolds
Apr 11, 2019 02:34 PM
oldolds88
Apr 14, 2018 06:41 AM
steedaq
Mar 27, 2013 07:56 PM
f-85
Dec 21, 2011 03:08 PM
