1970 radiator
If your car is a 4 speed I would try and find the correct radiator. In 69 the manual trans 442 with 3.23 gears non air non heavy duty cooling came with 3 row RAD with no automatic transmission cooler built into the pass side tank. The 4 speed cars with 390 and 433 had 4 row RAD , also without cooler . I thought the 1970 cars were the same. I am not 100% sure to be honest with you
1970 radiator
Hi
The expert told me 1970 manual trans 442 had the auto trans cooler built into the pass side tank. The inlet and outlet holes were capped with screw in plugs. You could have 3 or 4 rows depending on gear ratio and if the car had HD cooling or not.
4 row
I have a 4 row that has been pressure tested and had the ends soldered. I have a receipt to prove it was done in a radiator shop. I would take 300. Plus shipping . Call 573 822 4304 my name is brent
Alex72cutty
Apr 21, 2015 10:30 AM
Giddy
Mar 10, 2009 11:37 AM
