1968 Drivers Side Mirror
Old Apr 4, 2012 | 01:54 PM
tcarroll's Avatar
I have a 1968 Cutlass Drivers side Non Remote Mirror in decent shape however I do not want to risk marking the paint putting it back on as it has to slide into place and then must be secured somehow from the inside to keep it from jiggling. The factory had 2 large rivets that hold it. Does anyone know if the Re-pop ones are screwed on? Where is the best place to get one? Cheapest? If anyone has one for sale I am interested, any help would be appreciated. Thanks Todd
Old Apr 4, 2012 | 07:43 PM
allyolds68's Avatar
They aren't rivets. They are flat headed screws with an Allen head in the end of the screw shaft. They are tightened from the top. You should have a plastic gasket that sits under the mirror so there isn't metal against paint. I don't know if anyone sells just the screws but I would think they do. I'm fairly sure other vehicles from that era used the same system.
Old Apr 5, 2012 | 05:16 AM
ROCKETMAN269V's Avatar
Post 1968 Drivers Side Mirror
You may want to check your mirror; a lot of people had "issues" with these screws, because you had to turn them clockwise to loosen them, because they screwed in from the bottom. Someone may have drilled out the holes in the mirror if it was riveted on when you got it. Bob.
Old Apr 5, 2012 | 05:24 AM
boese1978's Avatar
Does anyone know where I can get the plastic gasket? I have the remote mirror.
Old Apr 5, 2012 | 07:49 AM
tcarroll's Avatar
Fusick.com sells the plastic gasket you are looking for
Old Oct 8, 2012 | 07:42 PM
jmt147's Avatar
Does anyone know the measurements on the flat headed Allen heads crews or a place to purchase them. Mine are stripped. Thx
Old Oct 9, 2012 | 12:25 AM
firefighter5174's Avatar
I think I have a junk 68 mirror with those screws. I'll see if I can locate it tomorrow.
Old Oct 9, 2012 | 05:39 AM
jmt147's Avatar
Great. That would be awesome!
Funkwagon455
Jun 6, 2014 07:03 PM
tcarroll
Body work
Apr 4, 2012 11:54 PM
FIJIBLUE72
May 15, 2009 11:21 AM
Willidog
Mar 29, 2009 11:41 PM
madwilliam
Mar 3, 2004 05:24 AM
