toronado/GMC motorhome 455 intake manifold
Old Apr 3, 2017 | 10:15 AM
CuttyShark's Avatar
From what I can gather the GMC motorhome intake had NO egr. However if there is a higher performance Toronado intake available for more torque I would like to know about it. I will be blocking off the EGR anyhow on the heads and not using the hot choke.
Shipping would be to Ontario California
Old Apr 3, 2017 | 10:27 AM
11971four4two's Avatar
MOTORHEAD
Hey
Local guy has intake he thinks / advertised as TORO
maybe this will work 4 you??
https://minneapolis.craigslist.org/a...063081693.html
GOOD LUCK IN YOUR SEARCHING
Cheers
b
Old Apr 3, 2017 | 10:42 AM
CuttyShark's Avatar
That works!! I researched that casting... https://classicoldsmobile.com/forums...ng-number.html
Turns out it is a 72 manifold for the GMC motorhome.
If you are local would you mind being a surrogate I can get an estimate on shipping. What does a thing like that weigh anyhow? 50Lbs? Fedex might box an ship it for me.
Old Apr 3, 2017 | 11:44 AM
droptopron's Avatar
delete
Why are you locked in on a motorhome intake? There are plenty of intakes out there with no EGR
Old Apr 3, 2017 | 11:47 AM
MOTORHEAD
HE was pissed off
going to scrap that
you do not
need a T intake
going to aquire???
Old Apr 3, 2017 | 11:54 AM
CuttyShark's Avatar
It has to be a Toronado intake. The Motorhome only works with the low profile manifold because the floor of the cabin is directly above. No other manifolds fit without building a doghouse hump in the flat floor.
Old Apr 3, 2017 | 11:55 AM
CuttyShark's Avatar
HE was pissed off
going to scrap that
you do not
need a T intake
going to aquire???
who was pissed off? That guy selling a manifold for $5? Might not be worth the shipping. Maybe I can find one in a local yard for that! If a 1972 Toronado came with no EGR I should be able to find one around here in Socal yards.
Old Apr 3, 2017 | 11:56 AM
droptopron's Avatar
delete
Oh OK. Going by your user name I assumed you were working on a Cutlass
Old Apr 3, 2017 | 12:01 PM
CuttyShark's Avatar
I am! But also a Motorhome. I am living in the motorhome. The Cutlass is a neverending story because the Body and Paint guy has had nothing but life setbacks. Hes had it 14 months. I have a 1970 Olds 442 convertible, in theory only. It is in 1,000 pieces spread around my property.
The Motor I am building is a spare one for the motorhome. I wont be using it right away I hope. BUt I cant have it sitting the garage like it is without oil pan and a manifold with block off plate and valve covers. I have the covers, just need the pan and the manifold.
The engine in the motorhome right now is unknown vintage with non-oem C heads (not original and likely not made for unleaded gas)
Old Apr 3, 2017 | 12:19 PM
MOTORHEAD
local it it is
he told me to never call him again
Old Apr 3, 2017 | 03:54 PM
oldspackrat's Avatar
I have a Toro intake, I'll try to get pictures today. Shipping a heavy intake from Indy to Cali will not be cheap.
Old Apr 3, 2017 | 06:23 PM
2blu442's Avatar
Scott, check the center between the two large ports for cracks. A few years ago I was trying to come up with one of these for a member here. I went through three of them before coming up with one that had a small enough crack that my machine shop could drill and pin it. Not sure why these tend to crack, but the first two manifolds I looked at were cracked down into the space below the ports. Also I had to have them hot tanked and magged before I realized they were cracked. John
Old Apr 3, 2017 | 07:20 PM
John,
Thanks for the heads up. I will definitely check that out. Hate to send the intake all the way to the West Coast for nothing.
Old Dec 29, 2020 | 02:51 PM
GMC Shorty's Avatar
Hey there.
I own a GMC as well and there are a ton of Facebook pages for enthusiasts...lots of info and help for owners.
Old Dec 29, 2020 | 07:18 PM
VC455's Avatar
Barely Registered
Originally Posted by GMC Shorty
...there are a ton of Facebook pages for enthusiasts...lots of info and help for owners.
Welcome to CO, Shorty.
The difference between CO and the Facebook pages for GMCs is that CO has engine and transmission experts whom you can count on to give you correct advice.
There are similar experts on Facebook, but there are also many wannabes posing as experts. It can be difficult, and expensive, to differentiate.
On CO the wannabes either get educated or chased off.
On CO you are much less likely to be faced with stupid posing as smart. Stupid gets called out immediately.
CuttyShark
Apr 4, 2017 01:37 AM
deltathunder
Apr 22, 2012 09:36 AM
56Super88
Aug 21, 2011 05:59 PM
Van Dashner
Jul 5, 2008 11:32 PM
Andrew240
Dec 22, 2007 01:54 PM
