67 442 Radio Faceplate / Bezel
Old Apr 24, 2014 | 03:09 PM
SHJohnson's Avatar
Looking for a faceplate / bezel for the stock AM/FM radio for the 67 442 dash. Let me know if you have one or know of someone who might.
Thanks!
Old Apr 24, 2014 | 03:53 PM
66-3X2 442's Avatar
I have it if it's the same as a straight AM radio. I'll check my parts book to make sure. $25 + actual shipping charges.
The parts book shows two covers for the AM/FM radio in 67. The right is the same with or without A/C. The left is different for A/C and non A/C. It could be you can cut the top area off of an AM cover to make it a two piece unit that will work. The dash bezels are the same no matter,so that may very well work.
Old Apr 25, 2014 | 07:12 AM
SHJohnson's Avatar
Could you send a picture and the dimensions? This car has A/C.
You can email it to shj60187@aol.com. Thanks!!
Old Apr 25, 2014 | 05:03 PM
66-3X2 442's Avatar
OK,I'll try to explain this the best I can. The dash bezel is the same for all 66/67 A-Body Olds no matter the options except Rally Pac(tach & gauges) & the wiper switch hole depth. Neither of these two options affect the radio hole. The radio hole is the same size for AM & AM/FM. The difference is the AM/FM has a slide bar on top that requires two side covers,right & left. The AM radios had a single one piece cover that has a thin piece of chrome/plastic connecting the right and left sides @ the top of the cover. All that is required is to remove the thin piece to make two pieces. You're lucky in the respect your car has A/C. The OEM cover for the AM/FM left side covers both the radio hole/**** & the A/C vent. That would be a very hard part to find. Yours having A/C makes it a lot easier fix. I can send you the one piece cover so you can see what I'm trying to explain. If it works like I said,you can pay me,if it doesn't,just return it. Let me know what you would like to do.
Mike Richards
Old Apr 25, 2014 | 05:52 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
I may have something..
Old Apr 25, 2014 | 06:10 PM
rroth01's Avatar
The Radio Plate for an A/C Car came in 2 parts.
A small corner to the Right of the Radio and a Corner to the Left for an A/C Car.
A Non A/C car has the Small Corner on the Right once again and a delete plate about 7 inches long that will integrate into the radio.
If I lived in a better neighborhood Id go back to my Barn and take a Picture of what you are looking for.
Ron Roth
30 Miles North of The Murder City
Old Apr 25, 2014 | 06:48 PM
SHJohnson's Avatar
Mike,
Sounds good. Send me an email to shj60187@aol.com and I'll give you my
address. (Don't know if we are supposed to put addresses in the forum.)
When the former owner installed the new radio, he didn't retain the
plate (s)....More than happy to send you the check if it works.
Thanks, Stephen
dancutlass
Oct 2, 2012 02:49 AM
delmontcrusier
May 28, 2012 04:30 AM
oldjunkster
Jun 6, 2011 06:54 PM
crazy'boutOlds
Aug 10, 2010 06:33 PM
501Paratrooper
Jun 26, 2010 10:16 AM
